Old 06-29-2009, 03:13 PM
niblettda niblettda is offline
Default Will wing conduit interfere with AP bracket?
I'm at the point of drilling for the wing conduit in my QB wings. Before I start making holes my only concern is per the Van's PDF Wing Wiring.
I'm planning on using an AP servo in the wing with one of the many brackets designed to augment the alieron to spar bracket. Will putting the conduit in the approved Van's location (the big hole option), ultimately be in the way of the servo?
From all the installed pictures of the AP bracket, I don't think so, but I feel no need to re-discover this problem.
David Niblett
RV-9A QB
http://www.n396dk.org
Old 06-29-2009, 04:05 PM
rwhittier rwhittier is offline
Default It shouldn't
While I am not sure which AP you are using, that large hole did not interfere with my Tru Track servo using the TT servo bracket.
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 06-30-2009, 03:13 AM
Roger,
I don't know which AP I'm using yet either! I don't plan on making that decision until stuff starts getting bolted into the panel. I think TruTrack and Dynon use the same mounting method and are about the same profile. I think the largest one out there is Trio's. I was hoping someone with a Trio will say if it's in the way or not using their bracket. I highly doubt it is, but always good to confirm.
David Niblett
RV-9A QB
Old 06-30-2009, 08:11 AM
mikehoover's Avatar
mikehoover mikehoover is offline
I installed the bracket in my right wing to see how/if it would interfere. Won't be a problem. Here's a photo:
http://www.aclog.com/rv-9a/images/Wing/DCP_1695.JPG
Hope this helps.
Mike
Mike Hoover
Columbia, SC
www.eaa242.org/
N194MH first flight on 08-26-12
Old 06-30-2009, 09:49 AM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Conduit IAW Van's Instructions
My conduit runs low and aft of the first lightening hole in the rib. This keeps the conduit well clear of the bell crank and the AP servo. The link has pictures of mine, no servo yet but you can see the bracket.
http://www.mykitlog.com/users/displa...og=82871&row=1
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 06-30-2009, 10:41 AM
Thanks Mike (both of you), that's exactly what I was looking for. Like I said, didn't look like it would be a problem, but rather find out now that later.
I love this forum. Van's must too. It's got to cut down on their support calls.
David Niblett
RV-9A QB
