06-29-2009, 02:54 AM
Experimental from certificated Lycoming?
What is the process that occurs to 'convert' a used Lycoming O-360 from certificated to experimental? (assuming that is the right question)
If one buys a mid-time or run-out certificated engine and wants to go the DIY rebuild (with all the parts shipped out for inspections, etc). Does that 'become' an experimental engine from that point on?
If one buys the certificated engine from Vans but hangs it on an experimental, then it remains certificated and requires A&P for future work? But what if one buys the experimental engine? Or, builds an ECI up?
Re-read FAR 43-10 and 43-1, but don't know where else to research. Maybe just point me in a direction to FAA guidelines?
Probably answered a gazillion times in the FAQ?
THANKS
RV-6A (ordering Fin Kit)
Wings, Fuse, Emp (QB)
Lyc O-360-A3A [awaiting teardown]
06-29-2009, 05:01 AM
If you put a certificated engine in an expermental airplane, the engine then becomes an expermental engine and cannot legally be returned to a certificated engine by any method I know of.
06-29-2009, 05:52 AM
not true.
as long as it gets signed off by an faa inspector it stays certified.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
06-29-2009, 05:55 AM
Hi RV
We rebuilt our Lyc. 0-360 that had come out of a Comanche that was flipped.
Since I'm not an A@P, I couldn't sign it off. We simply removed the data plate and renamed it a Smith-Morgan 0-360...perfectly legal.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
06-29-2009, 06:48 AM
In my case the FAA asked me to leave the data plate on the engine so they could trace its history, should something happen down the road.
This was after I had my hands on the inside of it, replaced the accessory case, changed an idler gear, and some other things so it would work in an RV.
In fact, I'm still using the log book from 1955.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
06-29-2009, 07:30 AM
Banned
I made an entry in the engine log book on the IO-540 V4A5 that the engine was removed from __________ by ___________ and is now in the experimental category. I documented the "overhaul" and kept all the yellow tags for the parts sent out for the required propstrike inspection along with the receipts for the required new parts. I had a new data plate made that clearly identifies the engine as "EXPERIMENTAL" with a new serial number (001), new mfg (me), and engine data. That replaced the original plate which I saved with my yellow tags and receipts. I plan to continue recording in the original log book.
06-29-2009, 09:08 AM
I see a trend -
Thanks guys - sounding interesting.
Using FAR 43.1 (c)(3) and combining that with guidance from the requirements for disposition in FAR 43.10, it would seem that y'all are going by the concept that once removed from certificated status, you became the manufacturer and the engine was a bunch of parts which could be used in an experimental engine you then "created" from those parts.
The disposition section 43.10 - covers documentation to control the parts and they are no longer used in a certificated environment. The on-going A&P requirement to certify work performance and readiness to return to service falls on the 'manufacturer' during build -and later, presumably under the 'repairman cert' - while personally owned and operated. Upon disposition to a third-party, that owner must again have an A&P certify and perform authorized work, but it is still an experimental engine.
Is that close? Sure seems that EAA would have guidance derived from FAA regs that would provide the newbie as well as the 'repeat offender' in this area.
Appreciate the comments and it is soundlng 'reasonable' so I hope I don't sound unloyal to say that I'll continue research along those lines and post what I find.
Owner of a certificate O-360-A3A and future owner of an IO-360-A3A experimental engine ... manufactured by me.
06-29-2009, 09:16 AM
I'm trying to figure out what you're asking here  If you end up with an "experimental" engine, then there are no requirements to have an A&P sign anything at any point in time.. You can do whatever you want to that engine at that point.. and there are no third-party sign-offs required.
There are no "conversions" from certified to experimental... that happens automatically once you (not an A&P) start messing with it  No signoffs required for that...
Radomir
RV-7A sold
06-29-2009, 09:50 AM
Struggling for the words ...
Sometimes my words get in the way of a conversation ... sorry if I'm confused, just looking for enlightment.
I'm using the term 'conversion' more in the sense that it is 'no longer certificated' - as you describe, once I start "messing with it." Not a formal ceremony or stamp of approval process, just that it 'became experimental'.
Seems that it's more of a declaration of independence, as stated by some, and the person making that declaration becomes the 'experimental engine manufacturer' - regardless of the data plate retention. That is the disposition phase - described in FAR 43.10. "Tag & Bag" for lack of a term, the certification is dead. Freedom to work on and maintain. But still maintain documentation along the way, for the record.
But if you sell that a/c with that engine to the next owner, he is not acquiring a 'repairman' status for continued maintenance, right? And, therefore, needs an A&P to sign-off airworthiness on work, right? (That's the third-party I mentioned.) And, since he's not the manufacturer, does he simply 'mess with it' and go on? Was not my understanding ...
Whether it can ever become 'certificated' again is beyond my pay-grade, but even as an experimental somebody has to maintain it. My focus is practical, the "here and now" phase. For my post-strike acquisition, I plan to evaluate, tear-down, document, ship/inspect/repair the parts, and rebuild/assemble under supervision and with help.
Wanting to stay on the good side of the freedom deal.
06-29-2009, 10:02 AM
experimental repair work
Anyone regardless of whether they built the airplane (or engine) can work on (read repair) an experimental engine on an experimental aircraft. He/she does not have to have any written or oral permission to do so. The regulations allow for anyone to work on an experimental aircraft.
The work being done is not the questionable issue in the eyes of the FAA. No, the real issue to the FAA is who can or cannot sign off on any inspections on an experimental aircraft. The FAA requires that only those who hold a "REPAIRMAN CERTIFICATE" for that aircraft or an A&P/IA be allowed to sign the aircraft off as airworthy.
It is a subtle difference but a very important one.
