Yes, the inlet ducts or ramps, depending on where you locate them horizontally, may require cutting down the side baffles. I did to get the requisite 3/8-1/2" clearance, but I also have read a couple other builder sites who have indicated leaving the fwd sides higher might have worked better. So long has you direct the air over the top of the engine, I suppose there are a million different ways to do baffles, at least that's what I'm gathering.
So will a couple pieces of fabric on each side seal as well as five or six?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
