Old 06-26-2009, 05:49 PM
Wiley Wiley is offline
Default good taildragger instructor in Texas
Just got my tailwheel endorsment from Ken at Promark Aviation in Burnet, TX.
Very nice guy. Used his supercub with o-320, tundratires, and VG. Open air space with many different grass strips and cow pastures. He has a guest house in the country very close to the airport you can rent. Nice couple of days with the wife. Highly recommend.
www.promarkaviation.net
Eric Wiley
RV-8 finished 9/15
Flying S Air Ranch (10XS)
Brownwood TX
Old 06-29-2009, 10:22 AM
Bushcaddy Bushcaddy is offline
Default How many landings?
Eric,
I want to do exactly what you did and get it over a 3 or 4 day period. How many landings did you do all together?
Don...
Plymouth, MA
Varga 2180; N2C
http://www.n2charlie.com
2013 Donation Made
Old 06-29-2009, 10:56 AM
Peterk Peterk is offline
Also a good one in the South Ft Worth area:
Robert Schulko at Spinks...Champ 817-781-9737 $80 plus $40 for instructor.
Old 06-29-2009, 07:58 PM
N131RV N131RV is offline
Default Mike McMains is very good
I posted a review about him:
http://www.vansairforce.com/communit...ad.php?t=38407
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 07-07-2009, 02:58 PM
I didn't count the landings, but probably 30-40. I had a couple hours in a J-3 with a friend the previous months. He stated it usually takes 7-9hours to get the endorsment.
Eric Wiley
RV-8 finished 9/15
Brownwood TX
Old 07-07-2009, 03:27 PM
the_other_dougreeves the_other_dougreeves is offline
The figure of 7-9 hours seems right, less if you're a quick learner.
As for the number of landings .... are you counting only 1 landing per approach? No, I'm not talking about bounced landings , but when I got some tailwheel time, we would make an approach, make one landing, advance the throttle, get about 50 feet up, flare and land again, and repeat that as many times as we could. It really helped with learning the 3-point attitude and where to flare.
Another great exercise is to get in a fast taxi with the tail up, then have the instructor stomp one of the rudders and have you correct. You learn fast that way
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
