Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
  #111
Old 06-29-2009, 05:08 PM
Danny7 Danny7 is offline
Originally Posted by Hard Knox View Post
Mike can rant, the NTSB can cloud the issue with pages and pages of paper, others can defend the "right to choose" any engine for their project, but the facts are that if an airplane engine were in use on the airplane in question, it would not have failed in the fashion it did. I know airplanes with airplane engines crash as well, but they would not have failed in this manner if a battery connection came apart.
FWIW
even if it has dual EI?
or dual EI and electronic controlled FI?
or lycomings IE 2?
nothing special here...
Old 06-29-2009, 07:02 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The point I was trying to make was with dual electrically dependent EIs on a Lycoming, the engine would have stopped just as surely as it did with the Sube in this instance.
The cases I was referring to involved Emag/ Pmags (sorry I can't keep these straight) and software/ mystery issues. One if I remember led to a successful forced landing on a highway. The search feature here unfortunately gives hundreds of hits so I can't find what I'm looking for. There have been other EI failures as well (fortunately only one at a time).
Point being primarily though is that any electrically dependent EI is going to go dark if power is interrupted and some are going to go dark for other reasons even with power there- sensor failures, mechanical failures, software glitches and maybe even board failures. In this case the Subaru had an SDS EMS (digital fuel and spark control) on it- which needs electrons to work.
The nice thing about a Lycoming is that it is set up for twin ignition already and you can use two different EIs, two of the same, two mags or a mag and an EI.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 06-29-2009, 07:44 PM
D Freddo D Freddo is offline
I think we are concentrating on side issues.Things mechanical and electrical. Some people should not be flying aeroplanes
Old 06-29-2009, 08:11 PM
TSwezey TSwezey is offline
You are probably right about this one David.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 06-29-2009, 08:21 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Default Thread deterioration
I am afraid this thread may be running its course to a conclusion if it is going to morph into the dreaded AUTO CONVERSION ENGINES ARE EVIL! vain.
Come on guys if you want to debate auto engines or proclaim your disdain or acceptance of them there are other threads to do that in. This thread holds a great deal of value in its content without rehashing that debate.
Go somewhere else to rehash please!
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 06-29-2009, 10:18 PM
Shockwave's Avatar
Shockwave Shockwave is offline
It sounds like he had a backup electrical system, with X-TIE and Buss Selector switches. Those switches were found in the off and normal positions.
Did he have dual batteries? Do you even need a battery if the alternator is supplying power?
If only he would have slowed down and become familiar with what he had.
Chanler Childs
RV-8A
Empennage complete
Building wings
Old 06-29-2009, 10:55 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Not accurate
The event in which you speak happened to a friend of mine. Although a Pmag failed, it was all pilot error from there. He failed to isolate the mag, (do a mag check in flight), went to full rich at a high altitude, didn't throttle back to get the temps under control and slow the advanced timing and ultimately VOLUNTARILY shut the engine down. If he would have simply switched to the good mag he would have been fine. He is a low time pilot with very little fixed wing time prior to building the RV.
I know you are a huge proponent of Alt engines and probably one of the few that can make them work. I am not and have seen too much in the way of lack of success for airplanes. They seem to work fine on Gyro copters and in cars but in RV's the success just isn't there. No real significant numbers of hours to show success. Quite the contrary. The collection of broken planes is growing faster than the success stories.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 06-30-2009, 04:13 AM
DanH's Avatar
DanH DanH is online now
This isn't about auto engines or electrical dependence....or shouldn't be.
There are perfectly reasonable ways to approach the construction and testing of even the most radical flying machine. And there are perfectly unreasonable ways.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-30-2009, 05:21 AM
videobobk's Avatar
videobobk videobobk is offline
This has been a helpful thread. A practical result--I did the TC bit yesterday, looking over a nicely put together 40% RV-9A. I probably listened more for "attitude" than I had before, and I had a better sense of responsibility than a few weeks ago. I came away knowing I hadn't met another out of control accident waiting to happen.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 06-30-2009, 08:03 AM
N8RV's Avatar
N8RV N8RV is offline
Default The enemy is us.
Captain Obvious here.
I think we (the homebuilding community) have created some of this mindset by selling airplane kits with the sales pitch, "Anybody with a moderate skill set can build an airplane ... it's affordable ... great performance ... etc."
If many first-time builders would limit their building and flying to the light sport class, we'd probably have a better track record. However, when a low-time, low-experience pilot buys into the concept of building his dream machine, it's often MUCH faster, MUCH more complicated than the spam can that he's been flying.
Maybe Mr. First-time Builder buys a basic RV kit but then wanders the rows of fabulous RVs at Oshkosh ... and strolls the candy-filled rows of vendors in the exhibition halls ... and reads threads here on VAF about how others have built in redundancy in their electronic ignition systems ... and suddenly his basic, VFR-equipped RV has sprouted various antennae and pretty boxes chock-full of information that he now has to process.
As others have said, building the airframe isn't all that demanding. However, when we start adding all of the bells and whistles that make our dream plane a reality, there's a requisite amount of time and energy that must be spent learning not only how to install the systems, but also how to interpret and process the information that those systems present while we're flying.
Some people, lured into the myth that building a plane is really not all that hard, find themselves ill-equipped to deal with the intricasies of installation, calibration and evaluation of their dream planes and would be better served to build a simpler plane and settle for less speed, less "wow" and more safety. However, they would probably be fishermen instead of pilots were that the case.
The more RVs that are completed, the higher the accident stats will climb, sadly. It's just an actuarial fact that we need to expect. However, building and flying within our true skill set and not our finances or egos will help insure that we don't become part of those statistics.
Captain Obvious out.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
