Old 12-09-2005, 09:46 PM
jcoloccia jcoloccia is offline
Default Dumb question about rivets
Here's a totally stupid question about rivet markings. I know that the one dot means it's an AD rivet, but I have the assortment from Aircraft Spruce and there are additional markings. Some of them have a dot and "01DC" stamped on the head. Others have a dot and an "R" or something stamped on the head. Still others have nothing. Are these just manufacturer markings, or do they mean anything?
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 12-09-2005, 10:31 PM
szicree szicree is offline
I don't know about the others, but the ones without the dimple are soft rivets. They have far less strength. Squash one of each in the squeezer and you'll feel the difference right away.
Steve Zicree
Old 12-09-2005, 11:00 PM
Actually, I meant that they all had dots, but some have funny other markings, and some don't. I'm using them since there's no marking I could find that reduced the strength below that of the hardened rivets, but I wish I knew what the other markings meant.
John Coloccia
www.ballofshame.com
Old 12-10-2005, 06:12 AM
Red Voodoo's Avatar
Red Voodoo Red Voodoo is offline
John, only the dimple (or other marking) in the center of the rivet head is significant, denoting the rivet material. The other markings are manufacturers marks. As you know, the single dimple indicates an "AD" (or 2117 aluminum) rivet (and doesn't that dimple make a great starting place for drilling the suckers out?). If you see a rivet with two dashes on the head, it's a "DD" (2024). A raised dot is a "D" (2017), a raised cross is a "B" (5056), and no mark is, as pointed out previously, an "A" (soft 1100 aluminum; used in fiberglass, to attach plastic wire tie-downs to frame members, and other non-structural applications). I know... WAY more than you ever wanted to know!
Ben R.
RV-9A #90217
First wing almost done
