Hi Fred,
the Aft fuse gets joined to the center fuse soon, and the side skins go on. This is when you match drill F706. If you go ahead and match drill/dimple F706 now, it will be difficult to get a good aft/ center fuse alignment.
You will find that you can get at F706 to dimple easy after you remove the joined sections later on.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
