Old 12-08-2005, 06:05 PM
weriderv8a weriderv8a is offline
Unhappy Bolt Reference Chart
As a new builder I am having trouble telling the difference between bolt sizes. Is there a downloadable reference chart available from someone?
Old 12-08-2005, 07:16 PM
Pick up one of these.
Very handy.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 12-08-2005, 09:46 PM
Build9A's Avatar
Build9A Build9A is offline
Default while you wait for the bolt guage
Check this out while you wait for the bolt guage order to arrive.
http://www.aeroparts.com.au/aircraft..._aeroparts.htm
RV9A N489JE - Flying
Eagle Neck Airpark
Shellmans Bluff, Georgia
Old 12-09-2005, 12:56 AM
fodrv7's Avatar
fodrv7 fodrv7 is offline
Default Workshop Aids
Try These:
Pete.
Down Under , Australia.
Old 12-09-2005, 02:00 AM
jcoloccia jcoloccia is offline
Very handy.
I have one of those....stupid thing doesn't work, believe it or not. They must have put the sticker with the lengths on it wrong because all the lengths are....well....wrong
I didn't catch it until months later when I went to use it for the first time and couldn't find a single bolt that matched the plans.
Go ahead and buy one as I'm sure it was just a glitch on the one they sent me, BUT check it out with some known bolts before you use it for real. I'll probably buy a new one myself, or just use the gauge that Vans put in the emp. kit.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 12-09-2005, 03:47 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default bolt sizes
Didn't your kit come with one from Van's? Mine did, in both aluminum and paper template. It only goes up through AN4, but there are very few bolts larger and you can mike them.
h
Old 12-15-2005, 02:49 PM
Default MT Prop
Thanks to those who replied with help on bolt sizes. Its **** being the new guy and just getting started.Been looking at Engine and Prop combos and got a Quote from American Propeller for the new MT Aluminum Constant Speed Two Bladed Prop. Anybody know anything about them or anyone using it? They say it's 9lb lighter than a Hartzel and has no R.PM. restrictionsfor undampened Lycoming 360 series engines. Any thoughts?
Old 12-15-2005, 04:43 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
I have the sticker model too, and it is sort of confusing. IIRC, someone correct me if I am wrong, the bolt length is the last line it crosses (or under the bolt). In other words, if it crosses the -7 and goes almost to -8 but not quite, it is a -7 bolt. I think the "last crossed line" thing is so they can account for variances in sticker placement.
Don't know if that explains your issue, but it threw me the first few times.
Edit: Just came in from the shop, and as usual, I was wrong If it crosses the -7 line, almost coming to the -8, it is an -8... I had it reversed above. Ooops!
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 12-15-2005, 05:10 PM
That is how it works, but mine's off enough that sometimes the bolt makes it to the next line, making the metric "last REALLY crossed line"...LOL. Now that I know how and where it's off, it's usuable but I end up triple checking everything just to be sure.
John Coloccia
www.ballofshame.com
Old 12-15-2005, 07:48 PM
Not on mine. If it cross the 7 line and is not quite to -8, it's an 8.
Bob Collins
St. Paul, MN.
