Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 06-19-2009, 11:52 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default AV80R connection to autopilot
Has anyone connected their AV80R to the autopilot? I would be interested in a diagram that shows the pin out from the unit. My plan would be to cut the computer end off the usb cable then hardwire it into my panel. I am currently using the AVMAP as my primary GPS but would like the option of plugging in the AV80R.
Old 06-19-2009, 03:13 PM
rvator51's Avatar
rvator51 rvator51 is offline
Hi Andrew,
On the Honeywell AV8OR USB to Serial Cable, the DB9 connector is wired as follows:
Pin 2 is Receive
Pin 3 is Transmit
Pin 5 is ground.
I just plug my DB9 connector into the supplied Dynon DB9 connector and it works great.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
