Marine setting mostly changes how the navigation functions work. For instance, lock to roads will be turned off in marine mode and on in automobile road. In your photos, it also looks like in marine setting, only the base map is active, not the detail map. You can actually change active maps by going into the menu on the main screen.
Guy
