Old 06-17-2009, 04:29 PM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default replacing governor gasket w/o engine removal?
Superior IO-360. The gasket between the accessory drive (prop gov) and the engine block is leaking. I can get to the nuts and it look like I can slide the accessory drive aft. I just don't know how long the internal housing of the accessory drive is and whether I will be able to move the governor enough to the rear to allow the new gasket to be inserted. I would rather not have to pull the engine. I did also buy the gasket for between the governor and the accessory drive. Anyone know if this is possible?
Old 06-17-2009, 05:24 PM
Radomir's Avatar
Radomir Radomir is offline
No, you do not have to remove the engine for that.. The drive gear is fairly long, but it's possible w/o much trouble.
I just installed the whole contraption when I was switching to C/S prop, and it was all done with the engine on
Radomir
RV-7A sold
Old 06-17-2009, 08:57 PM
az_gila's Avatar
az_gila az_gila is offline
Smile This might give...
...you an idea of the movement needed...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
