I need to remove and replace the L & R Slick mags (4300 series) on my RV-8 (O-360-A1A) to replace the gaskets between the mags and the accessory case. I have set engine timing before, but never removed and replaced a mag. I have a Slick timing pin. So.....what method is used to remove a mag, and then replace it after the gasket is changed?
Today, I removed the harness from the cover on the left mag, and found I could insert the timing pin all the way in when the flywheel #1 TC mark was at the 6 o'clock position. This does not seem right, but then WTHDIK? That's why I posted the question
Is there a PDF available that explains how to do this?
