Old 06-12-2009, 09:49 PM
AirbusPilot AirbusPilot is offline
Default How to set Magnetos for Starting???
Hi,
I have a Lycoming IO-360-M1B from Vans in my RV-8, my engines has a Slick 4373 and a 4370, I think but not sure just the left one is a impulse coupling magneto so I understand that I should start my engine with just left magneto ON and the right one grounded.
Please confirm because I have never start any aircraft (Cessna old 150, 172, 210, Piper Cherokee, etc) that I remember with just left magneto, always both.
Old 06-12-2009, 10:34 PM
rwhittier rwhittier is offline
Default Yes, you start only on the left
with the right grounded. If only one is a IC mag. That is normal on a lot of planes.
Originally Posted by AirbusPilot View Post
Hi,
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 06-12-2009, 10:43 PM
yakdriver yakdriver is offline
If you have a key switch it should ground the right mag when you engage the starter. If you just have a right and left mag switch you start it on the left mag.All of the airplanes you mentioned have a key switch that grounds the right mag when the starter is engaged. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 06-12-2009, 10:49 PM
az_gila's Avatar
az_gila az_gila is offline
Smile If you have a key...
...switch, the right is grounded when the key is in the "Start" position.
That's why the Cessnas and Pipers don't usually have "Left mag for start" in their Check Lists....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-12-2009, 10:56 PM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Just to clarify, the RH Mag being grounded during start by the Start Switch. This is not necessarily the case, it is an option with the Switch - via a link present or removed. For instance, our RV-8 has the standard Key Mag/Start switch, yet leaves both Mags on for start (Dual Impulse Slicks).
Andy Hill
RV-8 G-HILZ
Old 06-13-2009, 06:29 AM
Hi,
The thing is that I fly an old cessna 150 (continental O-200) and 172 (lycoming 0-360). Both aircraft start check list said to set switch magnetos to both but those aircraft have a separate start bottom from the switch. So does those aircraft have both magnetos with impulse coupling or may we starting them with the wrong procedure for years????
Old 06-13-2009, 06:35 AM
brianwallis's Avatar
brianwallis brianwallis is offline
VAF moderator
Hi,
Only the left mag has the impulse coupling, and it's the one that will provide the juice to get it started, the right mag comes online once operational rpm is attained.
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings !!!
AP/IA COM/Multi/IFR/350 type
Old 06-13-2009, 06:38 AM
Mel's Avatar
Mel Mel is offline
Hi,
If the starting procedure says to set the switch to "both", then chances are pretty good that the engine is equipped with dual impulse magnetos. Otherwise, you would be replacing starter drives regularly.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-13-2009, 07:06 AM
Thanks for the answer, anyway I will check what kind of magnetos has those aircraft because they do not have an original check list and also at list 150 has lot of maintenance troubles with the starter
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 06-13-2009, 07:10 AM
Mel's Avatar
Mel Mel is offline
Another point is that the older starters turned much more slowly than the modern ones. The older starters may have been so slow that the early firing of a non-impulse mag wasn't such an issue. I assure you that the modern starters will create a problem if a non-impulse mag is on line during start.
