Old 06-12-2009, 07:03 AM
tomhanaway tomhanaway is offline
Default xm weather-one subscription dual feed?
Can a single xm weather antenna feed be split to both an AFS 3500(or4500) and a garmin 696.
I believe the antenna serial #is used for the weather subscription.
Tom H.
Old 06-12-2009, 07:37 AM
Geico266's Avatar
Geico266 Geico266 is offline
That is an excellent question.
Could you build a "splitter" and connect the male miniUSB to two male miniUSB's? I don't see why not. Could not hurt to try.....maybe.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 06-12-2009, 08:19 AM
mburch's Avatar
mburch mburch is offline
Short answer: Sorry, can't be done.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 06-12-2009, 11:19 AM
turbo's Avatar
turbo turbo is offline
Default 2 cents
i took someone's xm antenna and it worked in my unit. it was working in the other unit just before so would it have worked in both units at the same time? sounds like you should try and if it works dont tell anyone. my 2 cents. i had an antenna go bad so i did some testing with another unit.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 06-12-2009, 11:21 AM
Jamie's Avatar
Jamie Jamie is offline
There are many reasons, but mainly because of this -- the communication between the antenna and the gps itself is bi-directional. The antenna is not just a passive antenna...it's the actual receiver with it's own cpu.
