Old 06-07-2009, 04:10 PM
GEM930 GEM930 is offline
Default EFI fuel supply system
I'm installing an electronic ignition/electronic fuel injection system on my 0320 H2AD and had a question I was hoping the group could help me with. The supplier of the system (Tracy Crook at Real World solutions) recommends drawing from and returning to the same tank and using a transfer pump to move fuel from the other tank. I have opted to do this to simplify installation and cost (duplex valves are EXPENSIVE!!!). I installed 2 bulkhead fittings in my left tank (one for return and one for transfer) The facet pump will act as a one way valve (keeping fuel from the left tank from flowing to the right), but will allow fuel to flow from the right to the left tanks when the pump is off. My question is --- is there a problem with this? I can't really think of a situation where this will be a bad thing. If the plane sits a while with more fuel in the right tank, the tanks will equalize, but this does not seem to be a bad thing. Can anyone think of a reason why I would not want to do this? I could put an electric valve (primer) in the system, but I'm not sure it is necessary. Just for info, I plan to leave the original valve in the system. In case of pump failure I can always suck off the right tank and return to the left and then switch back. It will also leave me a way to completely shut off the fuel in case of an emergency landing. Any info will be greatly appreciated.
GEM
Old 06-07-2009, 05:00 PM
TSwezey TSwezey is offline
I would do what ever Tracy has on his. He knows his stuff very well. Send him an email or call him. He will answer any questions you have. Just make sure you know their vacation schedule. They are usually away when you have the biggest problems. My engine controller was built by him.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 06-07-2009, 06:17 PM
Tracy uses a header tank, which is just not an option for me, due to space.
Old 06-07-2009, 08:20 PM
N941WR's Avatar
N941WR N941WR is offline
Yes duplex valves are expensive but they are a very simple solution compaired to adding a transfer pump.
Simple is best when dealing with your fuel system.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-07-2009, 08:50 PM
John Clark's Avatar
John Clark John Clark is offline
Default KISS Principle
Way too complex with too many possible points of failure. Go with the duplex valve.
John Clark
RV8 N18U "Sunshine"
KSBA
Old 06-07-2009, 09:15 PM
nucleus nucleus is offline
Talking Your System Will Work
I would prefer the duplex valve solution as well, but it does mean adding another pump and return on the other wing, so it is hard to call it simpler. Remember this is EFI, so no mechanical engine pump.
I like the idea of having two pumps available... You are running a boost pump as well?
The system you have planned should work fine.
The biggest problem I see with transfer pumps is the scenario where it is ON when it should NOT be, and you pump fuel out your fuel vent. This is a pretty common problem by the way, airliners have done it.
If it were my plane I would have in tank pumps in each wing and a boost pump on the common line, but your system will work fine too.
Is Tracy flying his RV-8 yet? They haven't updated the website in an age.
Hans
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 06-08-2009, 08:20 AM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
I've been flying a fuel injected system with a purge valve for three years. I rarely use the purge valve, it is plumbed to pump from the right tank and return to the left tank. The purge valve is the only moving part in this setup...I don't understand the need to add more complexity (additional pumps) or cost (duplex valve) just to put the fuel back into the same tank it was pumped from. Should my system not be working as well as it seems to be?
RV7A-QB, RV-10
Old 06-08-2009, 10:25 AM
The system is an electronic system much like what is in a modern car. It continually returns fuel to the main (left) tank. If you tried to draw from the right tank you would quickly drain it and fill the left (perhaps to the point of dumping fuel out the vent. I agree a duplex would be the simple solution and if I were building from scratch I would go that route, but this is a retro. A duplex would require a mess of plumbing I'm just not willing to do now. My a&p pointed out the "con" of the increased complexity, but he also pointed out the "pro" of being able to move all the usable fuel to the main tank when both tanks are low. I already have a timing circuit that will keep me from pumping fuel overboard and I will leave the valve in place in case the pump or circuit fails. It just does not seem that complex to me. For good or bad I have ruled out the duplex at this time.... So back to the original question... Do I need to worry about fuel equalizing from the right to left tank? I can't think of a situation when this wouldl be bad... Can anyone think of one? Fuel will not move from the main to the aux and fuel could not be pushed out the vent as the tanks would equelize before that could happen. Sorry for any typos... Writing this on my iPhone.
Old 06-08-2009, 05:12 PM
frankh's Avatar
frankh frankh is offline
Default I don't think
Fuel equalising is a bad thing. the head difference of one tank being slightly higher than the other means the flowrate will be pretty low. Now of course you could add an Andair check valve (vans) or put a facet pump in there with the check built in.
certainly a Facet (even with an external check) is way cheaper than a duplex return valve.
frank
Inventer of the wingroot electric pump system.
Old 06-08-2009, 05:16 PM
McFly's Avatar
McFly McFly is offline
I am certainly not claiming to be an expert, but I cannot think of a reason why the tank equalizing in a failure/off mode would be a bad thing as long as you still have access to all fuel. Hopefully others will chime in. Good luck.
Hugh
Northern California
RV-7 Flying
