Old 06-04-2009, 08:41 PM
IH8slo IH8slo is offline
Default O-360 Static RPM?
I have a new O-360 (carburated) with the Sensenich 72FM8S9-1-85 fixed pitch prop. What is a typical static RPM for this prop? I'm turning 2100/2200 rpm and I know this prop is taking a big bite, but that still seems a bit low.
IH8slo
RV-7 (in work)
(my other plane is a Super Cub)
N.E. Texas
Old 06-04-2009, 08:51 PM
Geico266's Avatar
Geico266 Geico266 is offline
Sounds about right to me for a middle to cruise prop. Take off should be around 2300, red line 2600 due to prop restriction.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 06-04-2009, 09:19 PM
Mel's Avatar
Mel Mel is offline
The 72FM prop doesn't have the RPM restriction.
It's the 70CM for the 150/160 hp that has the restriction.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-05-2009, 12:01 AM
Tobi Tobi is offline
Thumbs up sounds good...
I have the same 85" prop on my parallel valve IO360 and see 2150-2175 RPM static.
Some other examples:
http://www2.sensenich.com/discuss/me...tml?1235135061
http://www2.sensenich.com/discuss/me...tml?1181502485
Tobias
RV-8 flying
Germany
Old 06-05-2009, 07:29 AM
turbo's Avatar
turbo turbo is offline
Default sounds about right
that is one solid prop. my static is about 2,200. believe max rpm is 2,700 with no restriction. sensi switched out my "83 with 900 hrs on it for a "85 for FREE. great people. mine has 2,600 hrs on it now.
the curve on the tip was put on backwards but passed testing so that is how come it looks "funny". i met the guy who did the testing and he told me the story.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 06-05-2009, 10:22 AM
Randy Hooper Randy Hooper is offline
Default O-360 static
I have 87" pitch and see 2150 RPM static. At 130kts 2500 RPM with a climb rate of about 1000 FPM.
These are general numbers without specific data.
Randy Hooper
RV-8
N84H
Old 06-06-2009, 05:43 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default O360-A1A 72/85 Sensenich Data Point
Today I tied my ready to inspect RV6 with an O360-A1A and a 72/85 Sensenich prop to our field (1B8) Turf Roller/Snow Plow Combo. (Its a "cut and shut" ex school bus with an ancient road roller in tow and adds to the very Norman Rockwell/Americana feel of the place). I checked out the static RPM and over 2 or 3 smooth power ups it never exceeded 2200 rpm. And the Field Service Combo didn't budge!
Jim Sharkey
RV6 - Waiting on the guy from the Albany NY FSDO
