Originally Posted by 647jc
The intercom manual describes two volume adjustment pots, one left and one right for the passenger headphones. This would not explain your symptoms exactly but might be worth your time checking. The puzzling part is the QFR works in stereo mode on the passenger side where the Bose does not.
Hi Joe,
When I called PSE awhile back, they told me those pots only adjusted volume for the rear seat passengers in a 4 seat aircraft, not between copilot and pilot. But your statement about the QFR got me thinking.... There are at least 3 QFR models and mine is the ANR "XC" Cross Country. Some are mono only. And some are stereo. I used mine in my old Cherokee for years. It hit me that it was a mono installation and there might be a switch on the headset that I'd forgotten about. Sure enough, a little internet research proved it did have a stereo and mono mode both. When I flipped it to stereo, it had the same symptoms as the wife's Bose, proving I had a wiring problem with the co-pilot audio wiring. I went panel diving after work and found that the three wires going to the jack were the right colors and re-confirmed continuity back to the correct pins on the PM 3000. What the heh! Never one to give up easily, I started clipping wire ties until I found enough slack I could remove the jack. Once that was done a close examination turned up a bad place where apparently "one who shall remain nameless" must have melted through some insulation with a hot soldering iron, effectively shorting the wires and turning it into a mono jack and it had gone unnoticed. As long as the QFR, or Bose, was in mono mode it worked but at half volume. An hour later everything was back together with new solder, heat shrink and it was thoroughly tested. The wife showed up at the hangar with a sack lunch and then we took a long walk down the taxi-way. She has her cherished headset working and life is good! Thanks for your help.
p.s. The Bose reps were very helpful and understanding while trying to troubleshoot my issue and one of them even built an RV-6. When I told them I had found the problem they told me they wouldn't even tell the wife it was my... 'er nameless's fault!
