Old 06-03-2009, 09:12 PM
Default Michelin Tube Valve
When I did my annual in January I replaced the tubes with Michelin Airstop units. Everything was fine flew to Key West, flew to Taylor Texas and a lot of local testing. In preparation for a trip to California I converted from the racing configuration to the cruise configuration and pumped the mains up to 45 psi. A couple of days before we were to leave (a couple of days after pumping up the tires) I went to the hangar to continue work on the plane and the left main was flat to the point that the wheel fairing was resting on the floor. I reinstalled the old tube but I also inflated the Michelin. The tube has remained inflated. The only thing I can think is the valve was leaking due to contamination, a freak close condition that resulted in a one time only imperfect seal or a valve defect that could recur at any time.
This is a request for reports of similar experience.
Bob Axsom
Old 06-04-2009, 06:56 AM
mannanj's Avatar
mannanj mannanj is offline
Default Tube
Bob:
Had the same thing happen to me with one of my Michelin Air Stop tubes. I couldn't duplicate it nor could I find a leak. I replaced the tube anyway.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 06-04-2009, 04:14 PM
DennisRhodes DennisRhodes is offline
Default HAve had the same thing happen
I decided that with the installation of tire and new tube that the tire ,wheel and all, captured the air between the new tube and tire. The tire being tight to the rim, captured the air like a tubeless tire would . Over couple days the tire did leak down and allow the new tube to inflate properly. With that the pressure that I thought was adequate went away! Bottom line was the tube was not inflated properly inside the tire. At least that was my thoughts when i found no leaks in the tube. I think the small volume tire and wheel may have something to do with that / DRR
Old 06-04-2009, 05:27 PM
Default Rationale doesn't quite match my timeline but ...
Rationale doesn't quite match my timeline but the fact that your tube deflated is significant. I had been flying with mine for months and only added air before the trip last weekend. My experience was not just a reduction in pressure like you would experience with an air bubble escaping from between the tube and the tire - the plane was sitting on the wheel fairing (without my racing subfairings thank goodness). Mannanj's experience makes three cases if yours was a Michelin AirStop tube.
Bob Axsom
Old 06-04-2009, 09:24 PM
mannanj's Avatar
Default Michelin
Bob Axsom
Bob:
Mine had been flying for months too, before I discovered it totally deflated and sitting on the wheel pant. I could not find anything abnormal. I removed the tube and checked for leaks by by inflating it to over twice it's normal size and immersing it in water. I could find absolutely no leaks.
My conclusion was that it must have been the inflation valve.
LAUS DEO
VAF788
Old 06-05-2009, 12:20 AM
Default Same here
I did the emersion test and I covered it with soapy water but could detect no leaks. I decided it had to be the valve which of course was reseated when the tube was re-inflated. Thanks for providing your experience.
Bob Axsom
Old 06-05-2009, 07:20 AM
Ironflight's Avatar
VAF Moderator / Line Boy
This is one reason that I always use a metal valve cap with a seal on my tire valves. It provides a redundant seal to the valve itself. We used to use tire valves in various inflater devices when I was in the diving business (decades ago), and it was not uncommon to see little leak bubbles, so I don't like to depend on a Schrader valve as a single-point seal.
Bottom line - I agree that a valve leak is likely Bob - put a cap on it and see if it happens again. (BTW - all flight-critical QD's have redundant pressure-sealing caps for flight on the Shuttle.)
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-05-2009, 08:26 AM
rv8or rv8or is offline
Default A bit Of Spit
A bit of spit, thats all it takes to check the valve if it is leaking. Learnt that as an after school hanger brat tending DHC2's. I always check valves after putting air in and it is quite common to get a leak through the valve.
If a leak is found just give a lift under the valve stem with the tool that removes tha valve and it will usually seal OK
As Paul says a metal cap with an airtight seal also doubly secures it.
Rob
Very Very Slow build RV8
Old 06-05-2009, 09:42 AM
Default Yeah I do that too but ...
I had a brass cap on the stem at the time the failure occurred. It was only finger tight though and obviously didn't seal. I think I am guilty of a missunderstanding of the cap hardware. There is an extra nut that I have been using as a jam nut to lock the cap in place but I suspect the nut has another purpose (like at the base on some applications) and should never be used as I have been using it - In many instances it will back off the cap as you try to lock it in place. Oh well, another well intended misapplication. This does not eliminate the basic valve failure but the change would allow the cap to seal more reliably. I don't know about the valve consistency, the maintenance of standards was given a real down turn in the Gore led reinventing of government in the US at least.
I looked in the Aircraft Spruce 2008-2009 catalog and found three valves offered for sale on page 245
High Pressure Valve Cores
#2300HV (Long Type, Length 1-3/16") Operating pressure range 70-2000 PSI from -10 F to 165F. Conforms to AN809-1. P/N 06-00397 ..... $3.85
#9914A (Short Type, Length 7/8") Same operating range as #2300HV, but doesn't conform to AN809-1. P/N 2525 .............. $1.39
Aircraft Tire Valve Core
#6035 (38-830) (Short Type) Operating pressure range 0-400 PSI from -65F to 350F. P/N 6035 .............$0.40
I removed the valve (core) from the Michelin AirStop tube and inspected it. I found part of the black plastic band was torn away at the rear edge (referencing the end inserted into the tube stem as the forward end) and distributed across the gap between the forward body and the rear threaded portion of the valve and continuing up across the threads in a non linear manner, like a scallop pulled off of the plastic band with one point of highest pressure - not spirialing around in conformance with the thread pattern. The tube contains the following marking:
AIRSTOP MICHELIN
5CG67 (Type III) Valve TR67
5.00-5 PN 092-308-0
3 15 08 MADE IN ITALY
I measured the length of the valve (the overall length does not change) with a micrometer and found it to be 0.774 inch or 6.192/8" which is less than the high pressure short type's 7/8" listed in the catalog. I am going to order a few of the P/N 6035 Aircraft Tire Valve Cores which have no length specified but look like the the high pressure short type cores.
I conclude that the problem is a manufacturing defect in the assembly and the failure will occur intermittently when the valve is actuated as when air is added to the tube or the pressure is checked.
Bob Axsom
P.S. I will add the spit test to my process.
Last edited by Bob Axsom : 06-05-2009 at 06:21 PM. Reason: Added tube marking information and post script
Old 06-05-2009, 05:44 PM
vlittle's Avatar
vlittle vlittle is offline
I had some bad experiences with Michelin Airstops recently.
I bought 4 tubes and all of them had the valve cores inset too deep into the stem. This prevented me from filling them with air or letting air out.
I removed the cores on two of them and ground the stem down by about 1/16", which fixed the problem. One other tube had a bad core when it was removed (left half of it stuck in the stem). I returned the two unused tubes to my supplier.
It looks like some bad quality control at Michelin.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
