Bill,
Match the wing/flap hinge half length with the hinge half length you previously attached to the flap.
NOTE: Some builders report short e.d. on the wing side when attempting to use the kit supplied hinge. To address that problem, some builders attach a slightly wider hinge half to the wing. My kit supplied hinge material worked just fine. YMMV.
