Old 06-02-2009, 12:01 PM
N999BT N999BT is offline
Default Grease for the Wheels
Does everyone use the grease recommended by Cleveleand for packing their wheel bearings, or do you use wheel bearing grease from Napa? I have always packed my bearings with Stalube, but maybe I should use the recommended (more expensive) airplane bearing grease. Currently the Cleveland manual recommends Aeroshell grease 22 or Mobil Aviation Grease SHC 100.
Brent Travis
N999BT
Flying
Old 06-02-2009, 01:55 PM
shuttle's Avatar
shuttle shuttle is offline
Default Aeroshell 5
Brent,
My understanding is that Aeroshell 5 is typically used for GA a/c wheel bearings. Aeroshell 22 is an even higher spec grease (even wider temp range) also designed for use on wheel bearings.
See here:
http://www.shell.com/home/content/av...greases/about/
Steve
p.s. Aeroshell 5 is mineral oil based. Aeroshell 22 is synthetic. Thus probably not a good idea to mix them.
Old 06-02-2009, 04:23 PM
rocketbob's Avatar
Any good EP grease works better than the antiquated Aeroshell #5 or #6.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 06-02-2009, 06:54 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default Synth grease
I've had Redline CV2 synthetic grease cure wheel bearing, cv joint, blah, blah, pretty much kick butt stuff for everything but correcting my poor omelet-flipping technique. It's non-av stuff, but it works.
Rick 90432
