Old 06-02-2009, 07:34 AM
Camillo Camillo is offline
Default Stick grips common point wiring?
This morning I wired the stick grips.
I have Tosten grips with external Ray Allen relay (RAC-2), in order to have electric elevator dual control.
I will use of course the hat switch for elevator trim, then trigger (PTT), index (autopilot disconnect) and right button (maybe radio flip-flop).
I understood that wires from both grips have first to join together and then proceed to the appropriate place (i.e.: RAC-2, radios, etc...). Am I right? Or shall I expect something wrong at the end of the wiring process?
Thanks.
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
