Old 05-31-2009, 06:42 PM
Bruce's Avatar
Bruce Bruce is offline
Default Lord Mount Washers
I have figured out the grooves on the mounts but the question is that
the washer goes on the bottom ONLY ?????
Or top and bottom.
Have plenty of washers after I got the bolt set from Vans.
Getting ready to hang the engine.
Thanks in advance.
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 05-31-2009, 07:31 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Bottom washers...
Or top and bottom.
Thanks in advance.
Boomer
...on the engine "ear" side (between the engine and the rubber biscuit) are essential or the mount may hit the case.
The plans show this.
The other washers can be used as spacers for engine alignment with the cowling.... but if you don't have the cowl fitted yet, they should not be needed...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
