Old 05-31-2009, 10:41 AM
carl nank carl nank is offline
Default Fiberglass
I have been reading the tips in fiberglassing forums and I found a number that said we need to use west systems on the tips when filling the ends.
It is my understanding we were to use West Systems on cowl and non gel coat fiberglass, and polyester resin in the gel coat glass, because the gel coat fiberglass uses polyester.
Can someone confirm this for me?
Carl Nank
Western KY Lakes Region
N39CN
RV7-A, Superior IO-360, 180HP, Hartzell, Dynon D100, D10 & HS34. Garmin 430W & 327 xp. PS Engineering 8000B audio w/3 light marker beacon. Approach Avionics Pro Hub.
Cut Instrument panel myself. I installed avionics myself. Panel is powdercoated a beautiful dark blue crackle.
Old 05-31-2009, 11:32 AM
DanH's Avatar
DanH DanH is offline
Carl,
For structure, epoxy on epoxy/glass composites, epoxy or polyester on polyester/glass composites. Remove the gel coat prior to any structural bonding.
If "filling the ends" means correcting cosmetic surface issues (fairing adjacent surfaces, divots, and low spots), the same rules apply for fillers.
For pre-paint surfacing, polyester primer-surfacers are not well regarded. Old tech, better choices available.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-31-2009, 10:05 PM
Default Thanks Dan
I guess I did not need to spend $30.00 on everclear resin since I already use West systems.
This is how we learn.
Again, Thanks
Carl Nank
N39CN
Old 05-31-2009, 10:36 PM
az_gila's Avatar
az_gila az_gila is offline
Smile OK, Dan, I'll bite....
I sort of like EverCoat FeatherFill, but it's a polyester one catalyzed with MEKP.
http://www.evercoat.com/productDetail.aspx?pID=70
What are some newer tech, but just as easy to use as FeatherFill, choices?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
