05-29-2009, 07:06 PM
Main Battery Contactor Smoke
I just hooked up the main battery for the first time. As with everything, it seems like there is a problem associated with firsts. In this case, the diode on the contactor starts to smoke. The contactor is from B&C, the ring on the diode is facing the battery. At this point, there is no load on anything.
Charlie Becker
N464CB. RV8A(es)
Certificate Issued
05-29-2009, 07:43 PM
It's definitely in...
...backwards, and is no longer functional...
Check your wiring. Is it one of vans parts hidden in heat shrink? - it could have been wrongly marked.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
05-29-2009, 07:58 PM
Gil, is only the diode bad or have i fried the contactor? Any idea of the diode #, I should be able to get one at the aviation section of radio shack.
Charlie Becker
N464CB. RV8A(es)
Certificate Issued
05-29-2009, 08:13 PM
The contactor is probably fine. And in fact, the purpose of the diode is to prevent arcing from slowing killing the master switch. You can continue your initial testing/debugging without the diode - just get a replacement from Vans or radio shack eventually. Many certified planes don't even have the diode.
RS (or other) should definitely have it. I think a 1N4001 (if memory serves) should do ya.
05-29-2009, 08:39 PM
As Kevin says...
...on the diode.
But do a check to make sure that you did not get "plus" and "minus" reversed at the battery end.... just in case...
Gil Alexander
05-29-2009, 09:12 PM
VAF Moderator / Line Boy
Look at it this way, you at least avoided reinventing the "NED" (Noise Emitting Diode - it makes a loud noise when connected backwards across a large potential - but only once!)
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-30-2009, 06:22 AM
Take a look
We have a document about contactors... second one down.. might be helpful for you.
http://www.verticalpower.com/documents.html
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
05-31-2009, 06:45 AM
Lets see - Red to + and Black to - ? Lets see, I reversed the battery . . . but not the cables!
Charlie Becker
N464CB. RV8A(es)
Certificate Issued
05-31-2009, 09:38 AM
That is at least good...
...to know (see my post #5...  ...)
The alternative of having badly (reversed) marked diodes would not be good.
Replace the fried diode and you will be good to go....
Gil Alexander
