Van's answer
Here's the response I got from the support person at Vans:
Michael, there are two ways. One way is to replace the skin. The other way is to use the correct hole on the rib. Dimple the correct hole and file around the edge of the dimple where it will crack. Use filler after it is riveted together. JB weld or something to that effect.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
