05-28-2009, 10:59 PM
Changing tires and tubes
I know it's not rocket science, but there ARE tricks to just about any trade...and I'm all ears! Many folks use baby powder to lube the new tubes when changing them out. I read (somewhere) that the stuff in baby powder that makes it SMELL good is granular, and actually acts as an abrasive...albeit a mild one. Non-scented talc of some sort was recommended. If so, what kind and where do you get the stuff? Secondly, I've heard that some put a thin coating of lubricant (like Aeroshell 5) on the wheels to help the beads set correctly. Comments?
Steve
Woodinville, WA.
RV-4...flying
IO-320 w/ Hartzell cs prop
05-29-2009, 12:02 AM
Just add this...
...to your next Aircraft Spruce order...
http://www.aircraftspruce.com/catalo...s/tiretalc.php
...and this Michelin guide might help --
http://www.bomar.biz/download.php?view.220
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
05-29-2009, 12:04 AM
Tire talc
Tire talc, Aircraft Spruce P/N 17-250
As to "lube" never use anything that is going to stay slippery like grease or silicone. The worst case is that when you get on the brakes, the tire slips on the wheel and shears the valve stem off. Not good. Soapy water is the answer if you need a little help, but with split wheels, I have never bothered.
John Clark
RV8 N18U "Sunshine"
KSBA
05-29-2009, 04:34 AM
Tire Talc....
also available at your NAPA store in a shaker can. Most have it, and if not, they can get it overnight. Faster than spruce if you need it quick!!
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
05-29-2009, 05:58 AM
When working with a new tube add just a breath of air to it. It makes it easier to get it inside the tire and it takes it's place eaiser. I've never used powder, might have to get some.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
05-29-2009, 09:32 PM
Gil, John, Chris, and Larry:
THANKS for taking the time to respond. Your input is very helpful (and I downloaded the Michelin manual...LOTS of fun info).
Steve
Woodinville, WA.
RV-4...flying
05-29-2009, 09:53 PM
I am only on my second set of tires, but I ordered them from Desser and they sent along enough tire talc to do the job.
05-30-2009, 06:52 AM
Sooo.........
.....is the warning against using baby powder valid?
05-30-2009, 04:27 PM
The baby power warning was heard here by me for the first time. My RV-6 will be flying 12-years in September. I have over 2,225 hours on the hobbs. I have used baby powder on the tubes inside the tires since day one. Never had to repair a tube yet.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Reason: grammar and spelling
05-30-2009, 06:01 PM
Baby powder is just fine to use.
I had a longggggggg discussion with the Michelin service department a few months ago. They actually just put out another service bulletin due to our conversation.
MAKE SURE the tires and the innertubes match.!!!! DRESSER has sent the wrong tubes for the tires.!!!!
Place powder in the tire and rotate till the inside of the tire is covered.
Place Innertube in the tire.
Place a smig of air in the innertube.
Rotate the innertube a min of 360*. This takes out the folds in the tube.
Line up the valve stem with the tire dot.
Put a little more air in the tire so it doesn't rotate.
Put hub halves together.
