05-28-2009, 12:28 PM
Wheel Bearing Grease Intervals
Does anyone know how often the wheel bearings should be greased? Is there a regulation that addresses this? Annually, every 100 hours, every 250 landings? I downloaded the maintenance manual from Cleveland but I can't find a reference to the timing.
Brent Travis
N999BT
Flying
05-28-2009, 12:57 PM
Appendix D
FAR Part 43 Appendix D (e) 7 states:
(7) Wheels- for cracks, defects, and condition of bearings
So, I suppose that it depends on how you determine the condition of bearings. could be that you take the bearings out, inspect, and repack them, the usual procedure. Or, give the wheel a spin and pronounce them inspected  Seriously, I have always done, and will continue to do, the real inspection but I suspect that annually is bit of overkill in most cases.
John Clark
RV8 N18U "Sunshine"
KSBA
05-28-2009, 12:58 PM
At the conditional inspection.
I inspect every year and replace the grease every other year.
If I flew more then maybe it would need it more often.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
05-28-2009, 02:44 PM
actually, I'm interested in what people find as experience for usage. Because I fly about 300hrs a year. So a once a year might not be good for me, may need sooner.
05-28-2009, 02:58 PM
After 2,225 hobbs hours over almost 12 years (1st flight Sept 1997), I only repack my bearings when I change tires. I DO NOT solvent clean them just repack with clean grease. IMHO, the once a year bearing inspection can be done without solvent cleaning. Others will have different opinions. Yes if there is something that I question during the inspection, I will solvent clean them to get a better look. So far, I have only solvent cleaned them once after sitting outside in the rain over a two-week period. They had spots on them and were replaced. I could see the spots without solvent cleaning but solvent cleaned them to get a better look. They looked usable but were not good enough for me. Bearings are cheap compared to the entire airplane.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
05-28-2009, 03:04 PM
thanks gary. I would think things should go a long time, after all, we should be in the air more than taxi on the ground.
05-28-2009, 03:18 PM
Seals
The wheel bearing service issue is all about the sealing (or lack of) in the usual Cleveland wheels. Most cars, with modern seals almost never need, or get, service because the seals effectively keep the grease in, and more importantly, the crud out . So when did you last service the wheel bearings in your car? Anyway, we need to look now and then because of the stone-age felt seals.
John Clark
RV8 N18U "Sunshine"
KSBA
05-28-2009, 05:45 PM
moderator
Every other year
This is my routine as well. When I do my every-other-year repack I like to clean them with solvent first for a thorough inspection first, just makes me feel better.
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse in box
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
05-28-2009, 06:25 PM
The Cleveland Manual...
...might be of interest here....
http://www.bomar.biz/download.php?view.1376
Note that the new expen$ive grease they now recommend is Exxon Mobil SHC 100
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
05-28-2009, 06:28 PM
Wheel Bearings
20 plus years ago I worked in the wheel and tire shop at O'hare for the "then largest airline in the world" Tires were good for about 30 to50 landings and the bearings got cleaned, inspected, repacked with each tire change. I think we tore down and built up about 150 per week.
tidbit...almost every tire in the fleet was a retread. 747 all wheels&tires the same( including nose gear) 737-300 main gear tires wheels same as 757 only 1/2 as many
I clean and inspect and repack every other year or if I change the tires. I fly out of a high hot airport and the little wheels spin up pretty good. If you do alot of T/O and Landings you should adjust your mx schedule.
cm
