Old 05-28-2009, 10:32 AM
flyboy1963's Avatar
Default Electroir crank trigger installation - NEED TIPS!
HI all,
looking for advice on how to do a bullet-proof crank trigger installation. ( old style, behind flywheel)
I do NOT want to be pulling the prop to trouble-shoot a finicky wire or pickup.
Mike at Electroair has been VERY helpful, but need someone to look over my shoulder while installing.
anyone had issues with running the wire from the pickup to the firewall? wondering if it needs to be in a more heat resistant sleeve?
thanks to any and all Electro drivers for any words of wisdom.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 05-28-2009, 11:15 AM
az_gila's Avatar
az_gila az_gila is offline
Smile The standard tefzel wire...
Originally Posted by flyboy1963 View Post
....anyone had issues with running the wire from the pickup to the firewall? wondering if it needs to be in a more heat resistant sleeve?
...MIL-W-22579/16 is good to 302 degrees F.
That should be OK against the case, but if you want added protection, a fiberglass sleeve can be added over the bundle and is good to 1200 F
http://order.waytekwire.com/productd...%20%2050'/
This sleeve would also be good over your EGT leads...
Using heavier gauge wire (say 18 g) will help the bundle be physically stronger.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-28-2009, 01:04 PM
flyboy1963's Avatar
Default wiring
Gil,
good advice as usual.....looks a lot like the insulation on the wires in my oven!
Many of the electronic setups have wire leads coils & everything above the case in the plenum, I wonder if this would be cooler than below the case, in the hot air ?
My coils are going on the firewall so they are in a moderate temp area I'd say.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 05-28-2009, 01:37 PM
rocketbob's Avatar
I designed a new trigger wheel in Solidworks to go on the crank, and am using a different VR sensor that is threaded into a block I have yet to machine. Its a GM vehicle speed sensor. I had the trigger wheel lasered and turned the crank clamping ring on my lathe, but have not yet worked on the block or the VR sensor. The purpose of this setup is to be able to change the sensor without having to pull the prop or flywheel.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-28-2009, 02:53 PM
az_gila's Avatar
Smile The plemun area...
Gil,
...is cooler, but your cylinders can easily reach the high 300's (and more......) and if you shut down, some heat soaking can occur - especially in AZ in the summer...
The fiberglass sleeve stuff is only 50 cents a foot, and weighs nothing, so it's really cheap insurance...
And yes, it probably is the same stuff that is inside your oven.
Gil Alexander
