Old 05-28-2009, 05:20 AM
tinman tinman is offline
Default Lexan Inspection Port Covers?
Is there a structural reason to not use a lexan cover over the aft fuselage elevator inspection ports? Seems like this is an important area and not inspected due to the difficulty of getting the covers off.
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 05-28-2009, 05:23 AM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default plastics expert needed
I asked the same a while back after seeing all the clear covers on the acros. Didnt really get any good answers. Needs to be strong, then etc but that should not be a problem with the polycarbonates etc available. It would look great, be very easy to inspect quickly and i am in if someone can suggest a suitable material.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 05-28-2009, 06:28 AM
N520TX's Avatar
N520TX N520TX is offline
Default YMMV but ...
I've been flying with lexan inspection covers since day one (July 4 2004) without any problems what so ever. I got the idea to do this from the DA20 Katana aircraft that I first learned to fly.
Ron Walker - 40XS
RV7a - Flying
RV10 - Flying !
FFI Flight Lead - www.FalconFlight.aero
Old 05-28-2009, 10:42 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Pictures?
Can you post some pictures of this?
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-28-2009, 10:57 AM
rvbuilder2002's Avatar
The inspection covers on RV's should be considered a structural component (as well as the baggage bulkhead panel and tunnel covers).
I'm not saying that a clear cover can not be made that is equal to the aluminum ones, but "mine have been ok since day one" is not a good reason that everyone should do it.
If someone makes a mod that reduces their wing strength to 2.5 g"s (I'm not saying that this one does that), then in all of their flying they never pull more than two G's, does that make it appropriate to say "the mod has worked fine on my airplane"....I don't think so.
My suggestion...Think very carefully about what the true value of a mod like this will be...and what the consequences might be.
Scott McDaniels
Hubbard, Oregon
Old 05-28-2009, 11:18 AM
John Clark's Avatar
John Clark John Clark is offline
Default Inspection covers
My concern is that just looking at a component isn't an inspection. On my last condition inspection I found a questionable rod end only because I did a "tactile inspection," tough to do through lexan.
John Clark
RV8 N18U "Sunshine"
KSBA
Old 05-28-2009, 12:16 PM
boom3's Avatar
boom3 boom3 is offline
I don't have a picture of them, but a guy I know has approx 2" round plexi windows in the elevator inspection covers. It looks great and is easy to look through. I plan on doing the same thing.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 05-28-2009, 12:35 PM
I believe some of the polycarbonates are way stronger then thin aluminum. I do agree that viewing is not as good as touching, but the point is that a quick inspection as part of the walk around would provide much more info then waiting for the annual and removing the panels. At annual, certainly remove and inspect fully(metal or lexan). Finding a thin strong and transparent plastic that would not scratch easily is the issue i believe.
Old 05-28-2009, 01:09 PM
the_other_dougreeves the_other_dougreeves is offline
FWIW, our CT uses 3" diameter plexi inspection ports at pushrod joints on the underside of the wings. Works great for making sure that the nyloc nuts are still snug and witness marks still line up. It's only used during preflight to make sure that nothing bad has happened; it's still removed for the annual and 100 hr inspection (we are required to perform a 100 hr even though we're not operating for hire....).
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 05-28-2009, 01:29 PM
John Clark's Avatar
Default Numbers...
The tensile strength of aluminum is around 70,000 PSI, the tensile strength of polycarbonate (Lexan) is 9,500 PSI. Engineer carefully. I really like the idea of a "window" in an existing aluminum cover. With a little thought, that could be just as strong as the original plate and easier to make aerodynamically correct.
John Clark
RV8 N18U "Sunshine"
KSBA
