Old 05-27-2009, 10:07 PM
Kenny Gene Kenny Gene is offline
Default Front seal Replacement
Hello all,
I have an XP Superior O-360 with 336 hours since new and my front seal just started leaking engine oil. Anyone who has changed a seal, how is it done and where can I find information before I continue woking on this one.
Thanks for your help.
Kenny Gene
Old 05-27-2009, 10:31 PM
PCHunt PCHunt is offline
Default I'm not good at Searching Forums, but.......
I managed to find this:
http://www.vansairforce.com/communit...al+Replacement
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 05-28-2009, 06:03 AM
Thanks, this a great start and help. I did purchase a split seal, it was 4x MORE than the regular seal,, go figure.
Are there any pictures or pdf file of "How To" from some manuel?
Thanks again.
Kenny Gene
Old 05-28-2009, 10:44 AM
N54SG N54SG is offline
I have done one on my Superior XP-400SRE. I replaced it with the 1 part seal, not the split seal. I would think the split seal would be easy. No need to stretch it over the crank flange. Probably the only real important things are to be sure the inner surface is 100% cleaned out, and what type of glue you use to install the new seal. I used Plyobond (sp?) Seemed to have worked just fine. I would probably have a metal pick handy. One with a right angle head worked best for me. Just stab the old seal and it comes out pretty easy. Probably why it is leaking.. haha
Good luck!
Lancair 360
Best Race Speed: 279.686 mph
Building Lancair Super Legacy
LaminarConsulting.com
N54SG.com
Old 05-28-2009, 10:46 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default PDF
Thanks again.
Kenny Gene
Here you go. It covers both split seals and solid seals. We recently did this on our engine.
http://www.lycoming.com/support/publ...fs/SI1324B.pdf
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-28-2009, 11:34 AM
David Clifford David Clifford is offline
Banned
I just did the front seal on my IO-540 and used the one piece. It was easy to install following the Lycoming method provided in the link above. My understanding is that the split seal is more prone to leak. ?
Old 06-03-2009, 12:17 PM
Thanks guys for helping me out on this one.
I've been in NYC on vacation for the past week (Had an EXCELLENT time!, Westin at Time Square, 2 shows, Lion King and Rock of Ages, Peter Lugars and Central Park!) so now I'm back in Kansas and ready to replace the front seal.
Thanks again for all your help.
Kenny Gene
Old 06-03-2009, 07:54 PM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default Front Seal
When I did some work on my original engine in my 6A I had to buy an overhaul gasket set for my O360. The IA that was overseeing my efforts noted that the kit had both types of seals, one piece and split.
This man was the engine guru for Tarrant County Junior College for a long, long time and knew Lycomings like the back of his hand. He picked up the split seal and said "You should throw this away, unless you want another leak up front!"
I took his advice and installed the one piece seal, it never leaked again. It looks pretty weird during installation but it returns to it's original shape and does the job it was designed to do.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
