Old 05-26-2009, 07:53 PM
Craig23's Avatar
Craig23 Craig23 is offline
Default Ray Allen Grip Switch Functions?
Hello everyone,
I'm thinking of using a Ray Allen grip G-205 grip in my RV-8 and had a question for anyone who might know the answer. I have electric elevator trim but manual aileron trim. I would like to use the button on the right side (typically used for right aileron trim) to activate my starter through a relay. I thought of using the left side button as my autopilot disconnect switch. Are the buttons in the grip compatible with those functions?
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
Old 05-26-2009, 08:26 PM
CNEJR CNEJR is offline
Default Do yourself a favor............
Go buy an Infinity Aerospace Grip, you won't regret it. Particularly if you want starter on the stick. It would be much to easy to hit the starter using right aileron trim function. Infinity,....that's the ticket. Starter, trim, fuel pump, flaps, ap engage, comm flip flop, PTT. Works great.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 05-26-2009, 08:31 PM
chaskuss chaskuss is offline
Default The answer is yes.
Originally Posted by Craig23 View Post
Hello everyone,
Craig,
Yes, you can do that with the G-205, G-207, G-305 & G-307 hat switches. This is possible because Ray does not use a cheap "4 into 1" switch like those used in computer joy sticks. The hat switch is actually comprised of 4 individual, high quality MicroSwitch brand switches. Each switch is rated at 15 amps, so you won't need any additional relays, either.
Simply wire up the left and right switches independently of the top and bottom switches. You can find the installation manual for your stick grip below. See
http://www.rayallencompany.com/RACme...ionsG2grip.pdf
Charlie Kuss
Old 05-26-2009, 09:11 PM
Craig23's Avatar
Default Thanks Guys
Thanks Chuck and Charley,
I'm not worried about hitting the starter button inadvertently because I have wired an enable/disable switch into the system right next to my mag switch. I wired up the relay and switch last night and got everything to function. Now I just need to run the wires up the stick and connect them to the grip. I didn't want to get a grip with too many functions because there's just not that much I want to operate from the grip. I may switch to a different grip if I'm unhappy with the Ray Allens, but I think I'll start there.
Take Care,
Craig
Craig Schwartz
N868RV
Santa Rosa, CA
Old 05-26-2009, 11:03 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Same set up
Hi Craig,
I have the same set up. Elec elevator trim, manual aileron trim. Ray Allen grip with the 4 flush buttons and the PTT on the front of the grip. The top and bottom buttons are elevator trim. The right switch is AP disconnect, the left is comm flip/flop.
I highly suggest to keep the stuff on the stick to a minimum, the KISS principle. Putting the starter on there even with a cut off switch is adding complexity that is not necessary. One more point of failure.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 05-27-2009, 07:43 AM
647jc's Avatar
647jc 647jc is offline
The switches in the Ray Allen G-205/207 grips are rated at 5 amps each so you would probably want to use a relay as you suggested in your original post if you want to control your starter.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 05-27-2009, 09:05 AM
Default Joe's right
Joe is correct about the amperage rating of the switches on the G-205 grip. I should have read the instruction sheet more carefully. My G-307 grips have 15 amp rated switches. (Microswitch model V3-15). Perhaps you could call RAC and ask them if a V3-15 switch can be substituted for use with the starter? Failing that, consider upgrading to the G-305 grip to get the higher rated switches.
Charlie Kuss
PS the 5 amp switch will work fine for the auto pilot disconnect.
Old 05-27-2009, 04:56 PM
Originally Posted by chaskuss View Post
snipped Perhaps you could call RAC and ask them if a V3-15 switch can be substituted for use with the starter?snipped.
I called RAC this afternoon, just out of curiosity. Ray said that due to space limitations, the 5 amp switches are the largest that will fit in the G-205 or G-207 grips.
Charlie Kuss
Old 05-27-2009, 05:23 PM
Webb's Avatar
Webb Webb is offline
You only start the plane once for a flight. I would pick out a function that you might do more than once.
Webb Willmott
Jackson, MS
N32WW
Old 06-08-2009, 04:24 PM
SabreKGB SabreKGB is offline
Well, hopefully...
Perhaps he wants it there in case of emergency?
