05-26-2009, 04:00 PM
How does Van's determine range values?
Kevin Horton - you might be a good one on this since you are looking at fuel burn, power, hp, etc....
All this info coming in lately dealing with fuel use, endurance, HP, etc…. makes me wonder how Van’s determined their range numbers.
If you use the 55% and 75% power range and do some math against how much fuel is on board, I wonder what they used for their standard and how it compares with the numbers that are posted by this group.
I have a 7A with an IO-360, 180hp, CS like Van’s using for reporting. If you use the range reported for the 180 HP setup and using that power setting and range, at 8,000 for 55% you get 5.28 hours, for 75%, you get 3.86 hours assuming there is no reserve. If you add 30 minutes for reserve (since these were designed as VFR planes), I increased the flying time by ½ hour and you get 5.78 hours and 4.36 hours.
Also it depends if the stats are determined if you run the tanks dry or allow for non-usable fuel (which I will call 2 gallons per side).
Now comes the comparisons for flow rates vs range by time (using Van's posted speeds for range):
Bone Dry (42 gallons)
55% - No reserve……5.28 hours……..……..8 gal/hr
55% - 30 minute reserve……5.78 hours…..7.26 gal/hr
75% - No reserve……3.86 hours………….10.8 gal/hr
75% - 30 minute reserve….4.36 hours……..9.6 gal/hr
With Un-usable fuel (38 gallons)
55% - No reserve……5.28 hours………….7.2 gal/hr
55% - 30 minute reserve…..5.78 hours……6.6 gal/hr
75% - No reserve…….3.86 hours…………9.8 gal/hr
75% - 30 minute reserve….4.36 hours…….8.7 gal/hr
At 8,000 feet, real numbers I would use for range calcultion is 9.2 gallons/hr at 75F ROP. Allow for 38 gallons usable fuel for a total of 4.13 hours of engine run time, and TAS of mph 190 mph. Take out 30 minutes reserve, and I can fly for 3.63 hours and cover 690 miles. Put the reserve in it and the range becomes 785 miles. According to Van's range for 75% power at 8,000 feet is 765 miles.
Therefore, I consider my range to be 690 miles.
So how does Van's calculate their range numbers?
It's amazing what you can think up when you are sitting at a meeting and don't have a dog in the fight nor do you want to be there after the holiday weekend.
Looking for other opinions or experiences on how Van's determined those numbers.
Webb Willmott
Jackson, MS
N32WW
Reason: Correct statement
05-26-2009, 04:55 PM
Use 1 gallon unusable TOTAL and see what you get. It should be close enough to their numbers.
05-26-2009, 05:04 PM
1 gallon unusable
751 miles with 30 minutes reserve.
Webb Willmott
Jackson, MS
N32WW
05-26-2009, 05:15 PM
751 miles (nm?) with 30 minute reserve is very close to the 765 mile number. It does not answer what their numbers represent or how calculated. In practice, I use 450-500 nm as my refueling/bladder/leg stretch range.
05-26-2009, 05:31 PM
Yep. I'd have to check my POH for unusable fuel, but when I measured it (for my plane) it was a surprisingly small number. No where near 2 gal per side - more like less than one pt.
05-26-2009, 06:23 PM
Statutory miles is what Van's uses so that is what I used for the numbers
And yes, 500 NM is also my upper limit. I totally agree.
KevinH - As far as usable fuel, I wouldn't be comfortable using a pint for unusable unless just straight and level. A few turns or coming into land and I think we would see a pucker factor inversely proportional to the dimenishing level of fuel.
Webb Willmott
Jackson, MS
N32WW
05-26-2009, 07:42 PM
I fly power settings and the stopwatch. My typical cross country profile generates a fuel burn of 8 gph from chock to chock at a cruise power setting of 65%. With 38 gallons, that allows me to fly 4 hours plus a 45 minute reserve at cruise speed.
With zero wind, that's 600 NM or thereabouts plus reserve, including a 20 minute cruise climb to >10k feet and a reduced power 300 fpm descent maintaining about 160 knots TAS. Comparing that to the data Van's publishes for the -6 (and doing some interpolating), I would say Van's information assumes no reserve.
With zero wind, my 600 mile range is roughly Atlanta-Houston, Atlanta-Miami, Atlanta-Oshkosh, etc, which is usually plenty for my derrierre and bladder.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
05-26-2009, 07:49 PM
4 hrs and 600nm w/o a pit stop ! We old guys are impressed! The Order of the Enlarged Prostate hereby dubs thee, "Iron Bladder."
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
05-26-2009, 08:04 PM
SWMBO might disagree. In all of our X/C trips, I'm the one who caused our only unplanned stop for a potty break. She still gives me grief over that...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
05-26-2009, 11:20 PM
Somehow I don't think Vans used fannies and bladders for posted range estimates (but in real life they most certainly do).
I agree with you that I don't think Vans is using reserves for the estimate. I also wonder about the amount of unusable fuel.
Webb Willmott
Jackson, MS
N32WW
