Old 05-26-2009, 08:18 AM
apatti apatti is offline
Default Source for 1" SCAT flanges
All,
Where can I get 1" flanges for SCAT (and other) tubing. I want to construct several blast tubes. I have checked Aircraft Spruce, Wicks, and Robbins Wings and the smallest I see is a 1.5".
Also, is there anything special about the screen used as a filter? Where can I get that?
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 05-26-2009, 08:45 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Flange: Aircraft Spruce 10350-4 $6.95 ea
http://www.aircraftspruce.com/catalo...uctflanges.php
Mike W
Venice, FL
N164WM
Old 05-26-2009, 09:23 AM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Default Screen
On mine, I just hunted down the cheapest stainless screen I could find ( I think Lowe's?)put a depression in it in the direction of the airflow and wrapped it around the flange. I then secured the SCAT to the flange (over the screen) with a wiretie. The aluminum screen you commonly see will work fine, it's just not very strong...
RV7A-QB, RV-10
Old 05-26-2009, 09:30 AM
noelf noelf is offline
Default The screen is easy...
...just look in the aircraft parts section of your local food supermarket. You should be able to find a food strainer...with stainless steel wire mesh / screen. I used this in the cabin fresh air vent ducts and the on the baffle area for the cabin heat muff.
The blast tube "flanges" can be found at ACS p/n 10350-4.
Old 05-26-2009, 10:02 AM
Thanks, guys. I guess I didn't use the right search terms with ACS.
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
