Old 05-25-2009, 07:01 PM
Default If you had a choice
If you had a choice of only one EGT sensor on four-cylinder Lycoming, which cylinder would you choose to install it on?
Old 05-25-2009, 07:23 PM
Mel's Avatar
Mel Mel is offline
Typically #3 runs hottest on most RVs.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-25-2009, 07:27 PM
what if we assume that #3 already has CHT probe?
Old 05-25-2009, 07:50 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
My EGT is mounted through a drilled hole in the #3 exhaust pipe.
edit: And I only have the one CHT & EGT. Both on #3
L.Adamson --- RV6A
Old 05-25-2009, 07:58 PM
Mel's Avatar
Mel Mel is offline
CHT probe mounts in the cylinder head. EGT probe mounts in the exhaust pipe.
Old 05-26-2009, 04:37 AM
L.Adamson --- RV6A
point taken thank you.
I've read somewhere that single CHT and EGT were installed on different cylinders and there was an explanation why. I can not find the discussion.
Old 05-26-2009, 11:00 AM
osxuser's Avatar
osxuser osxuser is offline
If I had only one, I'd put it into my 4 into 1 collector...
RV4 wing in Jig @ KPOC
RV7 emp built
Old 05-26-2009, 11:21 AM
Mel's Avatar
Mel Mel is offline
The EGT probe needs to be within about 2" from the flange.
Old 05-26-2009, 10:15 PM
osxuser's Avatar
Why? On multi probe setups this is true, but there are tons of airplanes that aren't setup that way on single probe.
RV7 emp built
Old 05-28-2009, 07:25 PM
Robert Anglin Robert Anglin is offline
Default pyrometer what?
I think it has to do with the little blue flame that likes to hide behind the exaust valve and only comes out very fast and if you have a good sociometric mix only a short distance into the pipy thingy. That way you can get a good pyrometer read on the top of his head. Listen to Mel on this one, hes been there done that..
Yours as always REA III #80888
