Old 05-25-2009, 08:28 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Shunt wiring running next to main feed cables?
Gents,
I plan on running my shunt sense wires bundled with my main feed wire that goes to my breaker panel (which is also bundled with my positive battery cable to the master solenoid).
Is this a bad idea? Is the shunt sense wiring sensitive to high current nearby?
It is a Dynon EMS system.
Paul
Old 05-25-2009, 02:26 PM
flickroll's Avatar
flickroll flickroll is offline
It is a Dynon EMS system.l
Have mine running in the same bundle as the alternator and the starter wires. No problemo.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 05-25-2009, 03:52 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Paul... the voltages are small...
Gents,
Paul
...from the shunt - usually 1 amp = 1 mV
Any magnetically induced voltages created by high currents affecting the two small shunt lines should be in the same direction, so the difference between the two shunt lines will remain the same.
First order quick analysis, but it says there should be negligible effect...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-26-2009, 01:41 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Signal & power wires
As a rule, it is asking for signal disturbance trouble to place any wire that is carrying a signal along side a wire carrying current in the Amps range.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
