OOPS- Screws ?????
Have the canopy done and ran into a problem. Used a #30 drill bit on ALL
the holes for the canopy so the 1/8 inch plexi bit worked and then took all
to 5/16 after the MC. NOW I ran into the problem. The back canopy has #30 holes on the rollbar and they need to be tapped for #6 screw. You know where this is going. HOLE IS TOO BIG. It did tap for the #6 but the holding power I don't think is there. Don't want to take to #8, because of the MCing that needs to be done.
I am going to put a few screws in and see if it will hold.
What about blue locktite?????
What else can you use instead of locktite????????
Thanks in advance and maybe I will have it figured out by the time I come back and check it.
Sikaflex is out on the rollbar but will use it on the back of the aft canopy.
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
