Old 05-24-2009, 07:31 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Default Connecting #4 wire to Alternator
I am running #4 AWG wire to the alternator. The terminals for #4 cable (and even #6) are sized for an AN5 bolt. The 60 Amp Plane Power alternators, however, have a 6 mm stud (about .236"). Even a terminal for a #8 wire is a tad oversized, so the #4 terminal is way big for the alternator stud.
How did you guys handle this? Do you just trim off some of the wire strands at the end so the cable will fit into a #8 terminal?
Thanks.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 05-24-2009, 07:41 PM
az_gila's Avatar
az_gila az_gila is offline
Smile No problem...
Thanks.
B&C has them... 4 AWG wire to 0.25 terminal - close enough to 6mm...
http://www.bandc.biz/index.asp?PageA...ROD&ProdID=181
Don't cut strands to make it fit a smaller terminal...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-24-2009, 09:14 PM
Frank Smidler Frank Smidler is offline
Default Drilled out hole on terminal
I had my #4 wire made at the local auto electrical shop. I bought the wire and terminals and fitted them together, then took them back to be crimped (no extra charge). The terminal I got was one that was a little smaller than the stud on the alternator but with a lot of material around the hole. I then drilled it out slightly to the correct size and still had a lot of material around the hole.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 05-25-2009, 05:01 AM
chaskuss chaskuss is offline
Default Burndy Terminals
I am running #4 AWG wire to the alternator. The terminals for #4 cable (and even #6) are sized for an AN5 bolt. The 60 Amp Plane Power alternators, however, have a 6 mm stud (about .236"). Even a terminal for a #8 wire is a tad over-sized, so the #4 terminal is way big for the alternator stud.
Thanks.
Jeff,
Don't cut the strands off to fit an undersized connector. That creates a point of resistance and weakens the wire. Gil's link to B&C is for Amp brand connectors. I find them to be to fragile in the high vibration environment under the cowl. The Amp connectors are made from a sheet of flat copper. The lug portion of the connector is rolled into a tube and the seam brazed shut.
I prefer Burndy brand terminals (now a division of FCI). I've commented on this before. See
http://www.vansairforce.com/communit...rndy+terminals
You can buy Burndy terminals at industrial electrical supply houses like Graybar. I've also found that Ace Hardware carries a limited supply of Burndy terminals, as well. Here is the Burndy part number for one style of terminal which will work ( #4 AWG ring terminal with 1/4" stud hole)
YAV4CL-TC14-FX
They have other part numbers which will also work, besides the one listed above. Below are two photos of a #2 wire Burndy terminal. This terminal is has an extra long barrel area. Burndy terminals come in standard and extra long barrel variations.
Use 3M "triple thickness" heat shrink tubing to secure and insulate the joint. This gives the wire extra support. See
The photo above is of a #6 wire with a small stud hole. I hope this helps.
Charlie Kuss
