05-23-2009, 06:53 PM
Originally Posted by RVG8tor
Larry,
Where is you pioneering experimental spirit. I am going all out, dual p-mags!
My comment is purely tongue and cheek, to each his own. I just like gadgets.
Cheers
My pioneering experimental spirit dimmed when my Light Speed Ignition took my RV-10 out of the air and into an emergency landing situation with two souls on board. Fortunately, I was barley able to make the airport I deverted to. Failure was due to heat soaked control module. Then when I learned the "wires" used in the Light Speed Engineering crank shaft position sensor is "plenum" or" speaker wire" my experimental ignition pioneering spirit "caught the last train for the coast."
When I realized LSE was trying to save $5.00 (or less) in wire cost at the expense of my safety I had to ask myself open question; "What else are they skimping on?"
http://geicodevelopment.com/light_speed_engineering
Yep, to each his own.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
05-23-2009, 07:57 PM
Wow, glad it turned our OK
Originally Posted by Geico266
My pioneering experimental spirit dimmed when my Light Speed Ignition took my RV-10 out of the air and into an emergency landing situation. Fortunately, I was able to make an airport. When I learned the "wires" used in the Light Speed Engineering crank shaft position sensor is "plenum" or" speaker wire" my experimental ignition pioneering spirit "caught the last train for the coast."
When I realized LSE was trying to save $5.00 (or less) in wire cost at the expense of my safety I had to ask myself opne question; "What else are they skimping on?"
At least this makes me glad I did not go with LSE, how long ago was this, I know P-mags have had their growing pains. In fact I had a guy at the Van's tent at SnF frown with I said I was going with the P-mag, he then said do your research. Which is difficult to do, this forum is one of the best resources, the bulk of the comments are positive WRT the P-mag but them maybe the people who have had problems with them don't post. I would share you concern if I found something along the lines you did with your ignition.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
05-23-2009, 09:11 PM
Lightspeed
To follow up on Larry's advice - I had two runups with failed Lightspeed ignitions and shut down both flights. (Actually three total but the other was resolved after the magic box was returned to me with the explanation that all was fine. Funny, it worked too....)
The other two were both due to a cheap computer style connector inside the engine compartment from the magic box to the Hall Effect Sensor. Took many hours of sweating and grief to clean up and get going again. When I complained about paying essentialy 10% of the cost of a whole system for a "new and improved" connector that they knew was necessary, they told me to go get a mag and leave them alone! Yo, double Lightspeed Moderator Sam, how 'bout letting this post stand....
Fortunately I had an excellent radio builder who took the cap and unsoldered the cheap ($1.10) connector and resoldered the best available connector that cost $1.95......!
So to answer the question about what else they short take on, I'd say most anything. That $0.85 cost me many hours of sweating grief at a strange airport once and a missed ooportunity to meet a great aviation legend the second time. Hope it hangs in there for a while more, but next time it goes in the trash!
05-23-2009, 09:27 PM
As the saying goes; "Once bitten, twice shy."
I might put an electronic ignition on my -3, but I put my family and grand kids in the -10. The extra cost and limited benfit (if any) does not even come close to out weighing the risk. Not even close.
Enough said.
05-23-2009, 09:37 PM
I understand risking your own life on experimentation, in a single seat airplane.
05-23-2009, 09:45 PM
The Electroair in the RV has been rock-solid, and am a happy customer. I have five of these systems...
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
05-23-2009, 10:17 PM
Man have we killed some coffee with this one!
Dual Slick mags.
Many of my Georgia RV friends have Single LSE/Mag, Single PMag/Mag, Single ElectroAir/Mag, Dual LSE and Dual PMag. I agree with Larry. In this area, safety/reliability and where I fly dictates dual Slicks on everything. As listed below, Mitch had a failure and "continued on with a borrowed magneto". My position has always been that I can land with a bad mag issue and usually get it repaired. I've seen many transients with regular mag ignition issues land at OKZ and in less than an hour be on their way without issue. If any of these problems had involved troubleshooting an experimental ignition system, the repair may have taken days. I further agree with Larry on exposing others to experimental component reliability. Not trying to start a discussion, but my take is a little different. I don't see why we have used electronic ignition, reliably, on cheap cars for years, but cannot have it in GA.
Originally Posted by Mitch757
Last week while ferrying an RV-8 from Oregon, we had the Electroair fail. We continued on with a borrowed magneto in place of the Electroair.
I left a message with the company and got a return call a few days later(after we got home). The gentleman said to measure resistance between the red and black wires out of the sensor. It should be between 600 and 800 Ohms. Also check for the +5 Volts at the top lug at the electronic box.
The Electroair rep said he would be unavailable for a few days..don't remember the reason.
Good luck,
Mitch Garner
RV-4 flying
Its a holiday weekend and they may be away for vacation. Just a guess.
Hope you get your problem resolved soon and don't take any chances. We have already lost two RVs this week. Good luck.
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
05-28-2009, 08:49 AM
Ditto...
Yeah, what Rocket Bob said! I bought one of Jeff Rose's first EI's for my RV4 back in the early 90's before pre-punch, pre-drill and pre-preg. He was and still is an innovative, brilliant Southern Gentleman. All the others including LS copied Jeff in one form or another. Jeff sold the business to some guys up North who continue to upgrade and tweak the setup. It has worked great on both my airplanes for thousands (yes thousands Larry  )of hours. I run a Bendix Mag as the co-conspirator and found the EI increased my cruise efficiency 1GPH on the RV4 and up to 3GPH at altitude in the Rocket at 32 degrees or greater advance(the mag of course is welded at 25BTC). Installed and maintained properly, they are far superior to Magnetos.
My Rocket's EI has been flawless. On both aircraft I use Denso L14U auto spark plugs and Accel auto wires, a must I found over the modified harness/aircraft plug setup.
My Dos Centavos.
Smokey
HR2
PS: If you like Dual Magneto redundancy, look at the G3i system, similar to the Unison certified system but much cheaper.
http://www.g3ignition.com/
06-08-2009, 03:14 PM
EI
just bought an old-style gold ElectroAir.
I expect the installation will be challenging, but do-able.
...but swapping A Slick for Bendix was not plug 'n play either!
I expect that in a room full of 500 -hour pilots, you will get quite a few hands when you ask who has had a mag problem.
I fully agree that keeping one mag should garner the advantages of their vintage and commonality.
...and adding one experimental EI will gain the advantages and disadvantages of their strengths and weaknesses, however we try to minimize them.
Mike at Electroair has so far given excellent support on ensuring my old system tests as functional before installation.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
06-11-2009, 07:29 PM
Electoair - Jeff Rose
For troubles, Jeff Rose was always willing to help me.
Try Jeff at: 423-622-8825
Barney in Memphis
