Old 05-20-2009, 09:54 AM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
Default Empennage jig needed?
Looking for some input here from the guys/gals who have gone before me. Recently I visited the factory and took the plunge, I am just getting started on my empennage. I have noticed that although Van's reccomends a wing jig, I dont see any mention of an empennage jig. But I have noticed quite a few builders sites (Checkoway's for one) that show builders sometimes use them. My question is, with the skins being pre-punched, is a jig really necessary? Doesnt the pre-punching give you straight tail-feathers or am I being naive? I dont mind doing the extra work for a straight airframe, just wondering if its a waste of time and effort?
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 05-20-2009, 10:12 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default No jig used here
This is my first build and I didn't use any jig. It was built on a 7'x3' work bench. Everything fit together very well. I will for the wings though.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-20-2009, 10:23 AM
AltonD's Avatar
AltonD AltonD is offline
No jig required.
The wing jig is not really required either. But, it makes it a whole lot easier.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 05-20-2009, 10:30 AM
larrynew's Avatar
larrynew larrynew is offline
Default No jig required
I'm just finishing the empennage and there was definitely no jig required.
Prior to building (this is my first), I read many websites and bought and watched the Orndorff (sp?) videos. I was somewhat confused at first but eventually discovered that the kits and techniques have evolved over time. I haven't taken valuable rivet time to research what has changed and when.
I have been very happy with the detail and accuracy of the plans and instructions. If they say "no jig", you don't need it. My biggest advice for the empennage would be:
"If the plans or instructions call for measuring and cutting or drilling ANYTHING, test fit first!"
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 05-20-2009, 11:16 AM
RV7Ron's Avatar
Default Thanks!
great input guys, thanks, pretty much exactly what I was thinking but just wanted a sanity check.
And Larry, definitely good advice, test fit first! And think it all the way through before committing to drill. I already screwed up a couple parts (nose rib, main rib and spar) by match drilling them and one of my holes came out too close to the edge. A $50 mistake! doh
Ron Duren
Mechanical Engineer
Denver, CO (KBJC)
RV-7 'Tip Up'
Old 05-20-2009, 11:19 AM
Jamie's Avatar
Jamie Jamie is offline
Ron:
The reason you see some folks using jigs...the first -7 tail kits weren't completely pre-punched and jigs were required then. These were the very early kits though. Mine was #1671 and required no jigs whatsoever. My airplane came out absolutely straight.
Old 05-20-2009, 01:30 PM
DGlaeser DGlaeser is offline
Default N/C to the rescue!
Originally Posted by larrynew View Post
... Prior to building (this is my first), I read many websites and bought and watched the Orndorff (sp?) videos. I was somewhat confused at first but eventually discovered that the kits and techniques have evolved over time. I haven't taken valuable rivet time to research what has changed and when.
The big change was the pre-punched rivet holes. I don't know when Van's started doing that, but it's a HUGE step for mankind Prior to that you needed a jig to hold everything in alignment while drilling the holes, whose locations had to be layed out and marked by hand.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 05-20-2009, 09:12 PM
Tell me about it. I'm building an older RV-6 wing Kit, not a prepunched hole to be found anywhere...haha
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
