Old 05-18-2009, 07:21 PM
pvans pvans is offline
Default Weight of a paint job
We did a little experiment here last week. We have had Dan Mauer here painting an RV8. Dan is a professional, has been painting airplanes for over 25 years. We decided to see what the paint job might weigh.
Our test was only partial, but the results are informative. We weighed the right wing all by itself before and after. No flap, aileron or wing tip. Dan then went through the entire process, acid etch, alodine, primer, extremely minor filling, and a thorough color coat of polyurethane.
We used a digital scale accurate to one tenth of a pound. After subtracting the before and after weights, the wing gained 1.6 pounds.
We estimate the entire airplane paint job to be 10 pounds.
Of course doing the same process for all the airplane pieces would be more accurate, but by the time we thought of it those had already been painted.
Old 05-18-2009, 08:31 PM
tcone1's Avatar
tcone1 tcone1 is offline
Just out of curiousity, how much did it weigh before paint?
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Old 05-19-2009, 06:57 AM
72.6 before paint. Wiring was installed as was heated pitot.
Old 05-19-2009, 07:16 AM
lucky lucky is offline
Default my RV8 total weight pickup was...
~17 pounds. 5 additional pounds on each main wheel and 7 pounds on the tail wheel. That also includes some additional touch up fiberglass work by painter prior to priming.
Lucky Macy
EAA Tech Counselor/Flight Advisor
Old 05-19-2009, 09:14 AM
Geico266's Avatar
Geico266 Geico266 is offline
I have heard guys say it adds 30-40 pounds. I could never imagine how that could be.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-19-2009, 09:49 AM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
10 lbs seems awfully light for all that paint. But then 30-40 sounds like a lot! I'm thinking that ~20 lbs is about average.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 05-19-2009, 10:43 AM
aparchment's Avatar
aparchment aparchment is offline
Default Roller
Perhaps they used a roller and a paintbrush ;-)
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
