Old 05-18-2009, 07:24 AM
Camillo Camillo is offline
Default GNS 430 breaker size
Hi. I'm a bit confused about breaker size for Garmin GNS 430W.
NUMBER
Someone says it needs 2 breakers.
I imagined it only needs one breaker.
SIZE
Shall I add PWR consumption for every function (i.e.: NAV + COMM)?
Thanks.
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 05-18-2009, 08:07 AM
az_gila's Avatar
az_gila az_gila is offline
Smile The Install Manual...
NUMBER
SIZE
Thanks.
Calls for a 5 Amp breaker for the Nav section, and a 10 Amp breaker (at 14 volts input) for the Com section.
The two separate supplies are part of the equipment built-in redundancy.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-18-2009, 12:39 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Gil is correct - the 430 looks to be two separate units (Comm and Nav) joined together in a common screen/control unit at the front. Two separate power supplies. I'm not sure that I'd call it "redundant", as each power feed supplies a different function - I'd call it "fault tolerant" because you still have one function if you lose another.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-19-2009, 01:02 AM
Default Thank-you
I've not bought it, yet. So, I don't have manual.
The one I found on the web is for a 24V and I was not sure it was the same.
I already have a COMM2.
However, I think I will still go with 2 separate bks.
Thank-you.
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 05-19-2009, 09:09 AM
az_gila's Avatar
Smile Check your e-mail...
Thank-you.
...listed on VAF for a copy of the manual.
Gil Alexander
Old 05-20-2009, 07:31 AM
Sorry. I can't see any new PM.
May you send it again, please?
Camillo
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 05-20-2009, 08:08 AM
az_gila's Avatar
Smile Send me a PM...
Camillo
...with your regular (non-VAF) e-mail address and I will re-send it.
Gil Alexander
Old 05-20-2009, 08:34 AM
Received. Thank-you.
Camillo
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
