Originally Posted by flyerfifty
Electroair ignition failed on my newly purchased RV8A on trip back to the east coast. I am unfamilier with the system and have put the aircraft in a hanger near Van's. Is there somebody out in the Portland OR area than can help me.
Weather looks good for the next few, would appreciate help as soon as possible.
Please call Jeff at (508) 726-9995
Can you supply more info?
1. How did it "fail"?
a. Does it not work at all?
b. Does it run rough?
c. Can you start?
d. Does it "pop" under high manifold pressure?
2. Are you using REM37BYs as spark plugs or automotive 386's?
3. Do you know where the fuse to the power wire (+12) is located?
Feel free to call me this weekend if you don't reach anyone as I have used one for over 1000 hours.
James
803-238-2113
... not affiliated with ElectroAir ... just a user
