Old 05-14-2009, 04:33 PM
LarryT LarryT is offline
Default Plug-in power cord question
I've re-posted because I incorrectly posted in the General Discussion section.
The 12V rechargeable Cooler/Warmer I purchsed at a "going out of business" sale turned out to be a well-disguised "open box" missing the cigarette lighterpower adapter.
Will any power adapter work? I don't want to start an in-flight fire, but would like to eat real, not freeze-dried food when going airplane camping.
Battery specs:
Orema Power Co. Ltd. Model UN6-6; 6V6Ah valve regulated sealed lead battery.
Constant Voltage Charge:
Cycle use: 7.25 - 7.45V
Standby use: 6.8 - 6.9V
Initial current: less than 1.5 A
The cord for my AV8OR says 5V 1.5A. Do they all step down the 12V source?
Larry
Old 05-14-2009, 05:03 PM
az_gila's Avatar
az_gila az_gila is offline
Smile The harder part...
...is probably getting a device with the correct plug at the cooler end.
My cooler has a reversible plug color coded blue and red. One way it's a cooler, the other way it's a heater...
Battery specs:
Larry
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-14-2009, 10:45 PM
Default Cooler/Warmer has a sliding switch..
Hot-Off-Cold. There is a small PCB in the vicinity of the switch. I suppose the polarity is handled by it.
If I have the right voltage going in couldn't I just crimp hollow pins on the cooler end to slide over the solid pins. If I hooked it up backward I could just slide the switch the other way. That's something I don't need to test in the car - I have a 3A max bench test power supply unit.
I wish the manufacturer would (could) sell me a service part, but like most consumer stuff it's a Chinese-made disposable product.
Larry
