Drilling F/G
The trick is to sandwich the F/G between a couple of blocks of wood, or even blocks of F/G. That usually eliminates the splitting caused by the bit grabbing individual layers as it goes through. Duller bits don't grab as well so keep using the same bit. Once I use a bit for F/G I put it in my F/G only bin because they do get dull pretty quick.
The littlel bit of fracture is cosmetic from a functional point of view. Just dab some resin as you mentioned, and move on.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
