Old 05-14-2009, 02:26 AM
intothinair's Avatar
intothinair intothinair is offline
Default Wiring harness - length, gauge.
Does anyone know the length/gauge of the wires in the Vans 7/9 wiring kit? I will fabricate my own wiring harnesses and buy the Tefzel wire from another source. Eg. 300 ft - 18 gauge, 100 ft - 14 gauge, etc. Thank you.
Old 05-15-2009, 02:25 PM
MCA's Avatar
MCA MCA is offline
My suggestion - rather than base it on Van's kit (which assumes a basic VFR steam gauge plane), put together a planning document with a list of all *your* electrical devices, each device's electrical load, and the appropriate wire gauge.
Then make a drawing that shows where each device is located. You can then ballpark the length for each device. From that you can total up your wire needs (add about 40% cuz it always just works out that way). Don't forget ground wires and the large-gauge wires too.
This is part of the planning process for a Vertical Power electrical system and should be too if you're wiring the old-fashion way. You can use something as simple as Excel and Power Point to do your planning.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 05-15-2009, 02:34 PM
hydroguy2's Avatar
This should get you started.
photo stolen from Steinair
