Old 05-12-2009, 08:05 PM
flickroll's Avatar
flickroll flickroll is offline
Default Rough Idle/Whirlwind 200RV
The idle on my engine (O-360-A1A) is rough/erratic. If I try to idle at 650, it will run 630 to 680. I have a brand new Avstar carb, 10-3878, and have installed new rubber induction tube connections. One thought that I have is the Whirlwind 200RV prop has lower inertia than either a fixed pitch metal prop or a Hartzell CS prop. Could this be a reason? The carb I THINK is set up properly. The mixture screw is 1 1/2 turns out from full in, and while it is hard to tell because of the erratic idle, it looks like about a 50 RPM rise when I pull the mixture. The timing (Slicks) was just set at 25 deg, and the plugs were just cleaned and gapped. Any ideas? One other clue is when I am shooting touch and goes I smell a little gas when landing and then giving full power for take off. Maybe still too rich? Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Last edited by flickroll : 05-12-2009 at 09:50 PM. Reason: change word from 'lean' to 'rich'
Old 05-12-2009, 10:55 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Too Low
My engine idles at about 760-800. Maybe you are too low. The lighter weight prop should make this better. It isn't a prop issue.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 05-13-2009, 02:53 AM
roee roee is offline
Darwin, just curious, but why would a lighter weight prop make this better? Like Jim, my intuition says that a heavier prop would be advantageous for a smooth low-RPM idle because of the greater flywheel effect to keep the engine turning between power strokes. No? What am I missing? Again, just curious to understand the issue. I have no idea if Jim's problem (if it's a problem at all) is prop related, I would guess not.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 05-13-2009, 05:42 AM
flickroll's Avatar
Let me try a little faster idle to see if that smooths it out. Duh...shoulda already done that...however I didn't try it because I thought I would get a smooth idle at 650...
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 05-13-2009, 06:23 AM
Webb's Avatar
Webb Webb is offline
Default Check mixture
Check your mixture. Different prop but mine was too rich.
Lean the mixture at idle and see if you get much of an RPM rise. If you get a bunch (>100), it's set too rich for idle.
Webb Willmott
Jackson, MS
N32WW
Old 05-13-2009, 08:57 AM
flickroll's Avatar
Best I can tell is it's about a 50 RPM rise. I say best I can tell cuz the RPM bounces around and it's hard to pin down the exact rise.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 05-13-2009, 10:25 AM
rich rich is offline
My 0360-A1A/Hartzell CS/ Slick mags runs rough below 700 rpm.
700 -800 rpm runs smooth.
Rich Rudolph
RV6A 900 + HRS.
Fort Worth,Tx.
Rich Rudolph
VAF#007
RV6A 2000 HRS.
Fort Worth,Tx.
Wright Brothers “Master Pilot” Award
Old 05-13-2009, 02:34 PM
SteinAir SteinAir is offline
Pretty common - extremely light props on big bore aircraft engines do not like slow idles without either a balance ring or flywheel of some sort. Heavy metal props rarely exhibit that issue, but it's common with wood.
It's a well known fact that wood/composite props that are really light will make extremely low idle speed pretty difficult....so that's probably just the penalty you'll have to pay with little to no weight on the front of the crankshaft.
That being said, a well tuned up Lyco with a Hartzell or other metal prop on it should easily and smoothly idle down in the 600's pretty easily. If you have to keep the engine at 800rpm and you have a FP prop, you'll never land!
My 2 cents as usual.
Stein
Old 05-13-2009, 05:49 PM
flickroll's Avatar
Stein, thanks for your response. I had a hunch the low moment of inertia on the Whirlwind 200RV could be the culprit. Looks like you've confirmed it. Thanks again
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 05-14-2009, 08:44 AM
breister breister is offline
It is even worse with high-compression engines. I have 10:1 pistons and idle below 900rpm is annoyingly rough even when leaned on the ground.
