Old 05-12-2009, 01:57 PM
Jamie's Avatar
Jamie Jamie is offline
Default In-flight ignition misfire procedure
Let's assume that you're airborne and notice (via your engine monitor) that one of your cylinders is not firing on one of your mags/EI. I had this scenario happen once when I had a fouled plug. The mag run-up was fine before take-off, but I guess the plug fouled after the run-up (I had an extended hold after doing my runup). In my case I detected the issue by noticing several anomalies on my engine monitor (higher FF, #2 peaking before #3, etc). I did an in-flight mag check and sure enough it was running rough on one mag.
Anyway...what is the correct procedure in this situation? Should you continue to fly off of both mags or just the non-offending mag?
Old 05-12-2009, 04:08 PM
frankh's Avatar
frankh frankh is offline
Default Hmm
I can't see why you wouldn't just continue to run on both mags.
All that will happen is the effective timing on the one cylinder will be retarded and thus slightly less efficient (this assumes you have 2 EI's or 2 mags..Both normally fire together) on the that one cylinder.
Seeing as no two cylinders ever fire at the same time the engine doesn't care. You might as well have the better efficiency on the remaining 3 cylinders rather than limit the timing of all 4 cylinders by turning off the offending ignition.
Now if you have one mag and one EI then the same thing happens except it will be less noticable if the offending plug is on the mag.
Frank
Old 05-13-2009, 05:31 AM
Jamie's Avatar
Yeah Frank, that's pretty much what I was thinking. I was just curious because I have read conflicting things.
Old 05-13-2009, 06:35 AM
Geico266's Avatar
Geico266 Geico266 is offline
Are you leaning on the ground while taxing & holding? I realize this was a one time event, but a different ground technique may have prevented it?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-13-2009, 07:00 AM
Jamie's Avatar
Yes, I religiously lean on the ground. I was ready to launch so I had already gone mixture full rich, heard a crackle on the radio, then a short final call, and then watched an L-39 proceed to do multiple 250kt passes down a different runway that the winds were clearly not favoring. The runways were intersecting and he was making midfield downwind (the upwind of the runway I was waiting at) in 20 seconds flat.
So basically I was stuck there until he finished playing. I should have leaned it back out. That's the only time I have had any fouling. Also, the plug needed to be gapped (which I did of course) so that may have aggravated the situation.
Old 05-13-2009, 08:46 AM
frankh's Avatar
Default A polite
Radio call might have been in order...Like "Hey there are other airplanes trying to use this airport if you don't mind rich boy!"...
Old 05-13-2009, 07:18 PM
Kahuna's Avatar
Kahuna Kahuna is online now
Both.........
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 05-13-2009, 08:23 PM
az_gila's Avatar
az_gila az_gila is offline
Smile I would say...
Originally Posted by Kahuna View Post
Both.........
...which ever option was smoother, providing no loss of rpm's....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
