Old 05-11-2009, 06:22 PM
CNEJR CNEJR is offline
Default I need a little advice......
Flying off the Phase I, everything is going well, but I need a little advice on calibrating a couple of things. My engine is an O360A1A, GRT Horizon I, EIS4000, Float senders, Standard Facet Pump.
Fuel Pressure is reading between 7-15 lbs, I think it should be about 5-6. I used the 200 resistor.
Fuel tanks are both showing same level on the EFIS & EIS, going down at the same rate. Left tank has 14 gallons, right tank is 19 gallons. Do you use a seperate resistor from the blue (4.8v) EIS excitor wire to each fuel sender wire? I had it this way originally, but was advised I just need one. Now being advised I need one for each.
I would like to hear from anyone who knows first hand. Thanks.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 05-11-2009, 07:57 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Yes, you need one for each. They are separate circuits and the resistor, along with the sender, creates a voltage divider that the EIS/EFIS uses to calculate fuel level. Check the sheet that came with the EIS. I think it is very specific about there being a resistor for each fuel level sender.
On the fuel pressure sender, I think there are differenct resistors used for different scales. I don't have the sheet with me but someone on the forum will let us know if the 200 ohm resistor is the correct one for a non-fuel injected engine. It may be that you have the wrong offset and slope factor entered.
Congratulations on working through Phase I.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
