Old 05-10-2009, 04:34 PM
dougknight dougknight is offline
Default Fuel Burn: Auto vs. Aero
Probably a dumb question but why the difference in fuel consumption per hour between different engine types.
RV-9A, 1100 lbs, O-320 Lycoming, carbureted, 2300 RPM (fix pitch wood sensinitch prop) = 8 Gallons/hr (give or take).
VS.
1971 ? Ton Dodge Power Wagon Pick up, 4000 lbs, 318 cu. In. V-8, two barrel carburetor, 2300 RPM (14 miles/gallon and 60 miles/hr) = 4.3 Gallons/hr.
Similar engines running the same duration and RPM, yet the Auto engine burns half the fuel while pulling 4 times the load. Just curious and figured someone here could clue me in.
doug
Old 05-10-2009, 04:39 PM
TSwezey TSwezey is offline
I don't want to state the obvious but the truck only goes 60 miles in one hour where the -9 will probably go 160 miles in an hour.
Truck 14 mpg where as the RV gets 20 mpg.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 05-10-2009, 04:41 PM
VS.
doug
It's horse power, Doug.
The V-8 is not producing near the power the 0320 is.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Geico266's Avatar
Geico266 Geico266 is offline
Dude, help the economy buy a new truck!
Dave has it right, I'm gonna guess the truck is running at 35% power?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-10-2009, 04:53 PM
I would also like to add that you would be burning a lot more than 8 gallons an hour in the pickup truck if it was going(if it could) 160 mph. The biggest energy cost is Drag and drag is related to the velocity squared.
Todd
N110TD
Old 05-10-2009, 04:57 PM
Smile
TSwezey
Not talking about time vs distance, talking time vs fuel consumed while running @ same RPM.
Geico266.Dude, help the economy buy a new truck
Spent all my $ on the plane. ha ha!
I guess I still don't understand how the truck can pull 4 times the load on half the fuel @ 35% power
doug
Old 05-10-2009, 05:04 PM
You are not doing the same amount of work! RPMs don't mean a thing!
Todd
N110TD
Old 05-10-2009, 05:26 PM
Smile
OK, The drag thing helps as does the amount of work, I guess.
If both engines were taken out of their respective vehicles and placed on engine stands side by side and run at the same RPM with no load. Would they burn the same amout of fuel??
doug
Old 05-10-2009, 06:00 PM
N941WR's Avatar
N941WR N941WR is offline
Check this thread:
http://www.vansairforce.com/communit...ad.php?t=27097
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-10-2009, 06:11 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Compare power not RPM
First, it's a fact that a good airplane engine like a IO-320 can produce 1 hp per hour on 0.4 pounds of fuel. The truck, even with FI, doesn't accomplish that or at least no better.
Second, you are not looking at the power factors, just RPM. You need to look at MAP, too if you want to make a comparison. Your MAP at 60 mph will be about 12 inches, more or less, maybe even less.
You need a vacuum gauge which is kinda like an MAP meter.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
