Old 11-29-2005, 04:04 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Question Help...Need to fix this
The coupler between the control unit and the valve assembly on my compressor was severed and I am not able to get the broken piece out to replace the coupler. There is no lip to grab onto on the embedded piece. I tried a screw driver and friction to turn it but it's in too tight and I was being carefull not to bend the soft metal. Any ideas from this very bright, intelligent and handy group?
Old 11-29-2005, 04:12 PM
Sears -- at least a good Sears store -- has extractors for this sort of thing.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 11-29-2005, 06:30 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Here's a picture of what you need
http://www.mytoolstore.com/hanson/extractr.html
Just get a size that fits in about halfway and tap in it in. Then you just turn it counterclockwise with a wrench while pushing on it a little to help it bite into the broken part. It will grab the broken part and screw it out. Spray some penetrating oil on it before you start. It usually works good.
The common name for this tool is an "easy-out".
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 11-29-2005, 08:02 PM
I think most hardware stores, actually, would have it. It's just a threaded instrument that runs opposite the thread of what you're trying to extract...so as you insert and turn it to put it into the bolt (or screw or whatever you're trying to extract), at the same time you're putting pressure on the bolt -- or screw or whatever -- in a direction that will unthread it.
Bob Vila has an answer for everything, I tell ya!
Bob Collins
St. Paul, MN.
Old 11-29-2005, 08:59 PM
Capflyer's Avatar
Thanks guys....this is exactyly the type of thing I was hoping existed.
Mike
Old 11-30-2005, 04:39 PM
94kb 94kb is offline
The extractor is a good approach but this can probably easily be removed by cutting through it with a Dremel cut-off wheel, small burr or even with a small file and a little work. Make a couple of cuts then knock the piece to the center of the fitting. The remaining piece will be easy to remove.
Ken
